I don't think this is an excellent 3dmark score for 8800Ultra
Sagan
Last month I built up myself a new system, I get scores on the early 13ks with 3dmark06. Friends tell me that I should be getting at least 14k-up to-16k. These are my specs.
q6600 2.4ghz @(3015mhz)
IP35-pro
4x1gb slot corsair ram XMS2 high performance
nx8800 ultra @ core:660mhz and mem:2300mhz /OC stock
620Watt PSU corsair
160gb WD hard drive 7200 16mb cache
Vista 64-bit Home premium
Picture below of 3dmark06 score
Rattle
probably about 1k higher
I got 13k with xp and a gtx and e6600 at 3.6ghz and the gtx was oc;d and everytime i have benched with vista I get about 800-1200 lower on 05 and 06
Sagan
When I ran 3dmark06 I'm labeled as lowest with similar PCs, I view the other matches and they do run XP ^.^
Time to install XP, again...
Rattle
if your really that concerned about benches then yes xp is needed and is still whats being used.
I would not reformat to xp just for a couple numbers lol, your system is running normally with a 3.0 quad and stock ultra. go play some games and do other stuff and if your happy with frames/settings then your all set.
jkr266
yeah, for some reason 3dmark still shows a fairly large performance difference, especially 05. But most games show little if any difference using current drivers. I think it was firing squad that did a test with a bunch of games last week that showed 5% beign largest peformance difference.
mentok1982
Hey guess what?
3DMark is not a game.
Post threads like this in the video card section, specifically the Nvidia section.
SuperKeijo
IP35-pro
620Watt PSU corsair
Ever heard of the Print Screen -button? Or did you just want to show of that samsung monitor there?.. :D
IP35-pro
620Watt PSU corsair
13169
man u shud be satisfied with a score like that. my pc can barely muster 6500 in 3dmark03 on xp.
Timbowens
Hey guess what?
Hey guess what? You're not a mod so STFU.
God I hate douches that think they are mods.
You could have said what you did and NOT been a dickhead.
Rattle
cpuz auto drops the multi even if speedstep is off, dont worry
Sagan
I have this kind of ram timings are 5 - 5 - 5 - 18
corsair 4x1gb 800mhz xms2
Could I OC it to better values?
