G
gizmo
Guest
Ok so here it is... my brother bought a new case.... so i took all his parts out from the old one and put it in the new one. Everything was plugged in the right way, i boot up the system and it gets to the bios fine... but as soon as it boots reboots and trys to go into windows... it just like locks up. So, i tried his HD on my back up computer and it got into his windows with no problem. I put a fresh clean HD on the system now and try to reinstall windows... The cd boots up and copies the files, when it gets to the part where it is like " System is setting up windows, it just stays there and does not wanna get any further. What could be the problem? I need help ASAP this computer NEEDS to be up and running asap
thnx
thnx
