bad sectors being sectioned off?
How would I know this ?
chkdsk?
Are they the same disk ?
No one is a internal WD Black 4 TB Drive the other is a WD My Book external drive.
There is your answers. they are not buildt identically. diffrent sector layout
he said they were the same before an RMA.
not worth the effort. My advice, pretend that you didn't notice the sizes were slightly difference and just carry on.My next question how do I make E drive smaller and the same size as F ? Is it possible ?
Whoever Installed windows didn't know how to do it properlyAnd what is up with that EFI partition on one of them?
More info:
https://en.wikipedia.org/wiki/EFI_system_partition
what is odd is that drive wasn't in the computer when windows was installed back in 2009. It was added in 2015.
I have a Pair of 4TB Blacks and they are smaller than yours. I feel ripped off.
Is why I only install windows with the 1 hard drive in the system so there wont be any surprises.My MB is old enough to not be EFI and I have a 100MB NTFS partition for basically the same reason. Sometime if you have multiple physical drives during install, the installer will put the 100M on one and the primary Windows partition on another. Had one recently where it put the 100M partition on a drive I didn't plan on leaving in that computer. Had to reinstall after pulling the 2nd drive as windows wouldn't boot with the 100M partition missing.
As for the OP, I wouldn't worry about it unless you have some kind of image backup setup that requires perfectly matching drive sizes.
