I am sure this has be done before but. is a single 1060 3gb better than 2 460gtx in sli?
Discussion in 'nVidia Flavor' started by rob2000, Apr 22, 2018.
  1. rob2000
    rob2000 Gawd
    970
    Dec 24, 2005
    thinking of budget upgrading, but not sure.
    My system is old and a little slow at some of the new games and without replacing everything. I was thinking a 3gb or 6gb card.
    1070 or better is not in the budget unless I get a used one.
    thanks for any input.
  2. KazeoHin
    KazeoHin [H]ardness Supreme
    7,862
    Sep 7, 2011
    A 1060 will be a huge improvement. Trust me.
  3. IdiotInCharge
    IdiotInCharge [H]ardForum Junkie
    11,707
    Jun 13, 2003
    Grab a 6GB card. Do not undercut on VRAM!
    AlphaQup and AceGoober like this.
  4. rob2000
    rob2000 Gawd
    970
    Dec 24, 2005
    like wow holy snikes! improvement or just a bit smoother? mostly playing pubg right now, and maybe will get Farcry 5
  5. horrorshow
    horrorshow [H]ardness Supreme
    7,211
    Dec 14, 2007
    Like "holy sh*t", the difference in PUBG between my GTX 960 (which is basically your 560 SLI setup) and a 1060 is night and day....
    It's pretty much twice as fast.
    Armenius and IdiotInCharge like this.
  6. DigitalPanhandler
    DigitalPanhandler Limp Gawd
    205
    Jun 30, 2016
    I second this, especially in todays day and age, and since you mentioned pubg...yeah.....
    FTR with system in sig, at 1080p low + 110 screen scale, +100 on core +200 on mem, 100-120fps can be achieved, however I now have a 1440p, and usually just run everything on high, so 70-80 is the norm for me......
    IdiotInCharge likes this.
  7. doubletake
    doubletake Gawd
    561
    Apr 27, 2013
    You can just follow the trail of GPU tiers going up.
    Your 460 SLI setup is about on par or slightly faster than a GTX 580. From there, a GTX 780 is about twice as fast as the 580. Then, a 980 is about 25-30% faster than a 780.
    A GTX 1060 6GB is roughly equal to a GTX 980 (bit faster in some games, bit slower in others). You will see a massive performance improvement, all while significantly dropping your power consumption and cooling requirements.
  8. rob2000
    rob2000 Gawd
    970
    Dec 24, 2005
    thanks for all the replies, gives me something to chew on, was gonna pull the lever right before xmas and then the mining guys bought everything. and drove prices up. but I think the 1060 6gb of some flavor will be what I get, I have seen some say the 3gb benchmark better for some reason. maybe driver issue I guess.
  9. XoR_
    XoR_ Gawd
    814
    Jan 18, 2016
    SLI adds input lag. Even GPU which would be as fast in benchmarks as your SLI setup would be massively better, let alone much faster GPU with lower power consumption
  10. DigitalPanhandler
    205
    Jun 30, 2016
    ....maybe was just flukes in the benchmark..... or wrongly listed....the 3gb 1060 has fewer cuda cores then the 6gb...
    GTX 1060 6gb = 1280 cuda cores
    GTX 1060 3gb = 1152 cuda cores...
    https://www.nvidia.com/en-us/geforce/products/10series/geforce-gtx-1060/
    really for all intents and purposes the 1060 3gb should have been the 1050ti....
    Algrim and Armenius like this.
  11. Comixbooks
    Comixbooks Ignore Me
    13,695
    Jun 7, 2008
    460 gtx Is from 2011
  12. rob2000
    rob2000 Gawd
    970
    Dec 24, 2005
    I said it was old. When I built this rig I just moved them from my old machine. Was going to buy a 970 then saw the new series was about to release. and So I waited. this rig is probably 5 years old or older at the moment now. but other then a couple games it ran everything well enough for me. Pubg was pretty smooth for awhile then the last couple large updates changed something and its been slow ever since, even reducing everything to low or very low.
  13. ssnyder28
    ssnyder28 2[H]4U
    3,553
    May 9, 2012
    Think about it this way:
    x2 460s in SLI is slightly faster than a 480 gtx
    x2 480s in SLI is slightly faster than a 680 gtx
    x2 680s in SLI is slightly faster than a 1060 6gb card
    Again the above are quick and rough estimates and assumes EXCELLENT scaling in SLI. So essentially even with perfect SLI scaling you'd be doubling your performance before even considering the increase to 6gb ram, not to mention less power draw, heat etc.
  14. KedsDead
    KedsDead Limp Gawd
    128
    Jul 22, 2016
    A 1050ti will give you that holy shit this is way faster.. and 1060 6gb.. and you might pass out.. so have some cold water handy.. and by all means dont get a 1080ti.. you might have a heart attack..
    MN Scout, alxlwson and sonsonate like this.
  15. misterbobby
    misterbobby 2[H]4U
    3,808
    Mar 18, 2014
    I think the rest of the specs of the PC need to be listed here. If someone is coming from a video card that old then it does make me question their other Hardware.
  16. CAD4466HK
    CAD4466HK [H]ard|Gawd
    1,218
    Jul 24, 2008
    His sig shows a 3570K paired with those 460's.
    I would think he would be ok going with a 1050Ti-1060. But being that Pubg and FC5 are his major concerns right now, I hope he has that i5 OC'ed to at least 4.5GHz to help make up for his lack of cores/threads, till he can afford to do a complete system upgrade.
  17. misterbobby
    misterbobby 2[H]4U
    3,808
    Mar 18, 2014
    I'm just on my mobile throughout the day so I guess signatures don't show up. And that's still a pretty decent fairly modern i5 and enough for a 1050 Ti in general.
    CAD4466HK likes this.
  18. DejaWiz
    DejaWiz Oracle of Unfortunate Truths
    19,068
    Apr 15, 2005
    Yep...hard to beat the performance for the dollar that a 1060 provides. I'd avoid the 1050Ti, even though the price tag may be enticing vs the 1060 right now.
    Rotate your device to landscape mode and the sigs will show up. :)
  19. DigitalPanhandler
    205
    Jun 30, 2016
    yep 1060 or bust....
    any other time id easily recommend the 1050ti for budget builds but it just doesn't make sense at the price point its at these days, vs the performance you get... I mean its retailing for what the 1060 SHOULD be retailing for....so...
    not to mention hes wanting to play some pubg, so..... he really needs as much as performance / vram as possible......(and yes cpu really helps that game too, but he can eek by so long as the video performance is there)
    DejaWiz likes this.
  20. Raendor
    Raendor Gawd
    845
    Sep 21, 2015
    Holy s... That was my revelation of the day. Thanks!
    DejaWiz likes this.
  21. Pillars
    Pillars Gawd
    518
    Jun 11, 2016
    PUBG is still a bit of a turd. Honestly, for competitive play I run everything low except AA and models on medium, view distance high/ultra. 1440p I framecap using my main PC. On 1080p with my HTPC's 960 I was still 100+FPS. Definitely go 1060 6GB, however you would also see big gains upgrading other things.. if your sig is correct - you could use an SSD.
  22. horrorshow
    7,211
    Dec 14, 2007
    Yeah, I can't really recommend purchasing a 1050 Ti at this point.
    Seeing as how its identical speed-wise to my current GTX 960.
    I don't think that level of graphical horsepower is worth more than say, $130 tops.
    Definitely 1060 or bust.
    DejaWiz likes this.
  23. rob2000
    rob2000 Gawd
    970
    Dec 24, 2005
    I was waiting for a sale on the 1060 cards the prices were going up and down a little and then one of my current cards fried, to where I was having trouble booting at all. so instead of waiting I looked online, Had read that best buy of all places was not charging a arm and leg like some of the others and bought a nvidia founders 1070 for $399 plus tax about $150 more than I wanted to spend but, it is something I use everyday and a lot. So I figured what the hell. found a store 30 minutes away that had it in stock.
    card works pretty good. however a problem came up. I installed the new card after removing both gtx460 and now my killer nic e2200 stopped working. I mean the system does not see it. was saying driver not installed properly but it won't let you install it because it says no hardware found. So I was offline a week until I could get a pci-e network card shipped, as nobody anywhere near me carries these at all. so $20 on amazon and I am back in business. I still cannot get the killer working, it was fine until installing the new video card. so weird. its a onboard version of the nic.
  24. vegeta535
    vegeta535 2[H]4U
    3,261
    Jul 19, 2013
    Wouldn't a 460 sli be useless now? Sli is shit with modern cards. The new sli profiles proabably don't even want to for 460s. 460 lack of vram also a huge issue with modern games.
  25. _l_
    _l_ I Am A Cock
    1,151
    Nov 27, 2016
    just turn down the graphics settings a bit and don't sit with your nose touching the display monitor and you'll be just fine
  26. rob2000
    rob2000 Gawd
    970
    Dec 24, 2005
    the 460s were running fine in pubg until one of the 8-12 gig updates. whatever they changed in one of them, started to really stress the cards, and they eventually died of old age as well. lowering the settings worked some of the time, but they started to artifact nonstop and one is causing the pc to crash on boot. so they are both kaput.
  27. Krenum
    Krenum [H]ardForum Junkie
    15,565
    Apr 29, 2005
    1060 6GB On sale right now at CDW outlet for $170
    https://www.cdw.com/product/GIGABYTE-GTX-1060-MINI-ITX-OC-6GB-B/5116967?pfm=srh
    *edit, they may already be sold out says to call. If you're gonna buy one get it now if their still in stock!
