My computer refuses to connect to the internet and I have no idea what to do . I've tried pretty much everything I can think of. Hell, I resorted to calling tech support and after trying everything they could think of I still can't connect to the net. I'll describe what's going on and if anyone can figure this out I will henceforth refer to them as my lord and savior. I've been working at this for hours and hours and I still can't connect.
Ok so here's the deal. I was trying to forward some ports through my WRT54G. I did that and went back to BT and I was still getting crappy download speeds and a yellow status light. I tried many different ports and still the same story. I ran a NATcheck and it said I failed on those ports even though I had opened them in the router. So then I got to thinking that perhaps there was some kind of interference between the modem/router my ISP gave me and my Linksys router. I thought it was a longshot but I figured I might as well be certain. So I unhook the Linksys and plug the modem/router directly into the computer. I immediately attempt to load up the router's configuration utility by typing in 10.0.0.2. After typing in the correct username and pass, the page won't load, much ot my chagrin. I hook everything back up to my Linksys to see if everything is working there, and it is. So I decide to try going to directly into the modem/router again after confirming everything is working fine with the Linksys. I get it all setup and try loading 10.0.0.2 again. Same story, won't load.
So I say what the hell and reset the modem. Here's where things go from bad to worse. After resetting the modem I try to load up 10.0.0.2 again and nothing happens, but this time it doesn't even ask for my username/pass, it just tries to load but can't. So I try to load a webpage, no go. I hook everything back up through the Linksys and now the internet isn't working there either .
I try everything I can think of, then I move on to tech support. We try everything they can think of and still no connection. After all that they tell me to go to the head office and get myself a new modem, which I do. Now I figure I should try hooking the modem up to the computer I'm on now. Once I get it all setup I check the connection. It works fine and every website loads up correctly. Then I try 10.0.0.2. Asks for username/pass, won't load.
So here I am, two different computers, two different OS's (Windows XP64 on my main machine and XPpro on this one), two different modems, and I can't get into the modem's configuration utility . The only difference between the two systems is on this one the internet is working, and on the other one it isn't. Right now I've got everything going through the Linksys with the connection split between both computers, yet it doesn't work on my main machine, and it does on this one. And like I said, everything was fine until I reset the modem.
Here's a quick rundown of some things I've tried and you should know before you try to wrap your brain around this conundrum:
Have the latest motherboard drivers for XP64.
Tried uninstalling and reinstalling the ethernet card (onboard) and the drivers.
Looked in the BIOS and everything is set up correctly there.
Have tried both static and dynamic IP's.
Have tried two different modems and still the same story.
Have tried a System Restore to a point when the internet was working correctly.
Right now I'm getting the ping I set up, yet when I ping my router I get no response.
The connection worked fine on XP64 for over 2 weeks.
I apologize for the length of this, but I'm at my wit's end here. I don't know what else I can try and I will be eternally grateful to anyone who can help me out. I hope I'm just overlooking something and I can get this fixed.
