Enduring_Warrior
- Sep 22, 2004
On the ASUS M4A78 with the Radeon 3300.
Is it possible to use that IGP with the 4800 series?
no you cant use hybrid crossfire with a 4800 series card.. it only works with the 3450 3550 3650 4350 4650 i believe.. but for sure i know it wont work with the 3850 3870 3870x2 4830 4850 4850x2 4870 4870x2 4890..
when you use one of the last set of cards it will auto disable the onboard igp on boot up..
3550,4650 and above are not supported for hybrid crossfire. Only 2400 pro, 34xx and 43xx are supported.
