your memory is dual rank with 16x512mb chips
the other kit is single rank with 8x1gb chips
your kit is slightly faster and older the only reason its not on the qvl will be that it hasn't been tested
whats missing from the qvl isn't what wont work just what isn't tested
the only kits you can be sure that wont work are those that are on the qvl and say they wont work at a specific speed but they should all work at 2133
8700k is ~9% faster single threaded 20% quad core 63% multithreaded
the only reason to change ram is that a higher speed kit could increase the cpu performance another 20% in some tasks like cpu limited games or lightroom but nothing in others as its really software dependent
