OldBuzzard
- Jun 6, 2004
I'm putting together a new Ryzen build and have the newer HX1000 with the option to switch between single rail or multi rail and a Sapphire Vega 64 Aqua and have a couple of questions.
First, which would be the better use of the HX1000. Single rail or multi rail?
Second would it be better to use two of the 6+2 pin cables and just use one connector on each, or use one cable and use both connectors? Also would that be dependent on whether I go single of multi rail?
Build is: Cooler Master MasterCase Maker 5, Ryzen 7 1800x (will probably OC), ASRock X370 Taichi, Sapphire RX 64 Aqua, 16 GB Corsair Ram, Corsair H100i V2 cooler, 2x Mushkin Reactor 1TB SSD, Pioneer Blu-Ray burner, and an AFT Card reader.
Any input will be gratefully received.
