activeboot
- Dec 22, 2015
a
Is it is still a valid and modern design for the price point you can get it used for compared to similar 1200W counterparts?
The Corsair Professional Series HX 1050 is 79 bucks on amazon of all places....lol how cheap are you trying to go? You had me thinking it was super expensive or something. Im not so sure about buying used power supplies anyway? I just have never gone that route (ive had ps burn up right after the warranty expired)Looking to get an affordable used power supply and was looking at either of these. If the HX1000 was priced cheaper than the HX1050 is it worth it to get it or just go with the HX1050? I did look at the AX1200 as a possible alternative but it's more expensive than either of those and i don't want the Corsair link-i versions.
I know that the HX1000 is based on a 2008 CWT PUC platform and it seems the HX1050 is based on a different CWT platform updated in 2011? Besides that is there any huge differences that set them aside?
The 1050 is also single-rail. I'd prefer to get a good multi-rail that has proper OCP over all the 12v rails. Also while it may be $79 that's probably in American dollars. Unfortunately in Canadian it's going to be much more expensive. I'm still thinking about going the HX1000 route or maybe an older 1200W power supply route (maybe an AX1200 but that's single-rail as well).
