I tried everything to get this to work properly. I previously had the card running in BAMT on a different rig and since then I moved the cards to my personal rig and watercooled and crossfired both of them. My personal rig runs windows and I figured the settings would be identical for the system. I was wrong...
I've used Furmark and Heaven to benchmark the cards and the temps are exactly where they should be.
I'm using cgminer 3.7.2 .
cgminer -o stratum+tcp://xxx -u 1234 -p d=xxx --scrypt
It does about 500 each now. When I had it running, I was doing 800 and 950.
Is there a setting that I need to set for watercooled setups? Do I need to increase voltage?
Setting the intensity to above 13 throws HW errors.
Using Catalyst 14.2
Any ideas?
Using Catalyst 14.2
Any ideas?
