Okay, I gotta gush a bit here…
DUDE…!
Looking at the hi-rez renders, clicking into them, seeing some of the details one might overlook on the screen-size images…!!!
The bottom back notch fittings to align the side panels, that bottom rear bend itself, how the flanges come together…
The slot notches on the top front to also help align the side panels, and the front panel inner flange with the way it meets the side panels with that reveal between the two…!
I want to say I see screw holes for the 2.5" SSDs (mounted on their sides, one side secured) on the bottom panel, nice…?
If you can get those tolerances, especially with the recessed screws, this will be one sweet little chassis…!
Drooling…!
Good eye on the details! The front panel's inner flanges also have that gap in the middle because that space is reserved for the interior middle board's flange to slot into:
And the bottom was made to accommodate one 2.5" SSD when FlexATX is used.
But when HDPLEX is used, there is enough space to accommodate two additional 2.5" SSDs
Here's a look a the bottom's holes setup:
As you can see, most holes have relational positions to other holes. In fact, most elements of Hutzy XS -- from flanges to vent holes -- have relational positions and/or dimensions to other elements.
It creates this sort of.... "simple cohesion" I suppose? It helps ease my mind in thinking that I have arrived at a rational/optimal decision for the element instead of just slapping it on and calling it a day.
P.S. posting this post with those images gave me an urge to lengthen the middle board's flange length to match the front panel's flange length... brb
edit -- here we go :
