Mohonri said:I looks like a barebones computer--they(/he/she) don't even install/configure the PVR software! Building a similar machine off newegg (but S754, onboard DVI and included component outputs, etc) got me to $462 (including XP Pro but not the remote). Components:
Sempron 2800 S754
Jetway S754 MB w/ onboard dvi, component out on bracket
512MB PC3200 DDR
120GB HD
Antec Minuet (that's the most expensive part by far)
DVD reader
XP Pro
I'm cheap, so I'd try to save money on the case, and use something other than XP Pro (knoppmyth, maybe?). Speaking of which, there doesn't seem to be a TV Tuner in that machine, either....
That's correct--they have a low-profile PVR-150. You can also find low-profile ATi 550 cards.dekard said:righto... no tuner either... for a streaming media box, dvd or mame it would be fine just as it is... i wonder a half height tuner could be installed in it... doesn't hauppauge make a half height pvr-150?
