Hi guys,
I'm gonna be getting a HD ready LCD TV soon and I'm thinking of setting up a mini HTPC to play HD video (not necessarily bluray or HDDVD). I've alot of questions so I hope you all can share with me if you know.
Firstly, my TV will only have one HDMI input (Regza) so I'm not sure if I should be switching between the inputs from my HDMI Dvd player and the HTPC or can I go for component video for the HTPC? Will component video be sufficient to send 720p signal to the TV? Is DVI output enough to display 720p?
Second, audio. a HTPC normally can output audio via fiber optic right? Can I play 5.1 DTS or Dolby sources and output to my amplifier with this? Or, will my audio be output thru the HDMI connector?
Down to the hardware now. My requirements are just to play media, no gaming or tv tuner needed whatsoever, therefore I want the lowest spec possible to save cost, but I do want mobos which has fiber and HDMI/component out. Also I would like to have those very small casings, like the mini Acer pcs, not those square Shuttle type casings. So, what mobo should I get? What would the minimum CPU + Ram I need to get?
Thanks all!
Thanks all!
