DeathSmasher
- Apr 14, 2006
As the thread title states which is better? All i well be useing this for is FPS games an i would like a 30incher! Thanks for all your input! Brian
HP, for sure. I tried the Dell and returned it due to a harsh anti glare coating. Got the HP and really like it. Less obtrusive AG and it feels quite responsive.
pretty sure they share AG coating as they're the same panel 0.o
How does the DoubleSight DS-307W compare against the two mentioned LCD's?
I would wait or get the U2711 now instead. The power difference is quite significant between the CFL and LED especially in the summer when your room is hot.
the u2711 is still CCFL, and the one I had got plenty warm. If heat is a concern get the HP zr2740w or one of the Korean eBay models.The U2711 was upgraded to LED with high gamut....
I went with the Zr30w. Not as many connection options but better for gaming and the wallet.
Pretty much. Dell has more inputs, if you want to plug in an HDMI source or something. That won't work at all on the HP.Seems like every time I look at these two monitors this one comes up as "better for gaming because of less input lag." Basically what it comes down to?
. If you are looking for a 30 I'd wait until they are refreshed.
When do you all think this might happen?
Yup; if anything, I'd say my ZR30w's is slightly 'harsher' than the U3011. I use the HP at home for gaming, and the Dell at work.
My pick was due to input lag measurements of course- the lack of an OSD and other inputs is a non-issue if you're only going to use it with a computer. If you need perfectly accurate colors, get a Spyder 3 or similar calibrator; I did this because I also use it to process photos from my 60D.
HDMI from what source?My HDMI can do 1920x1200. That should not be a problem.
I've used both monitors and they are equally nice, if I had to pick one or the other it would be the dell because of the button design and the anti glare. As for input lag you wont notice it on most games unless you are playing counter strike or something that requires precision reflex mouse movement, and even on counter strike you wont notice it unless you are playing esea with professionals.
In 2012. When in 2012? No clue, but we're already halfway through May.
