HP ProLiant N40L $249 @ Newegg Shellshocker - Right Now - 4:00PM - 11:59PM PT
Been waiting on this for months....
...and of course now, I have no extra funds available for it. :mad:
I can buy it and hold onto it for you until you've got funds. PM me. ordering soon :)
Craig
is this neo processor paired with a strong gpu that can even fit in this case powerful enough to emulate the wii using dolphin?
awesome deal.
add WHS + StabelBit DrivePool + LightsOut for $100 total, and you have a robust NAS.
or NAS4Free if you want Open Source
This is actually a great little server and has one PCIe slot. The Samsung low profile memory work in it great too. You can convert the 5 /14" bay into a 5th HD and use an eSATA to SATA cable to run it and also run a SATA drive off the board itself. Does RAID 1/0 IIRC too.
I'm sure you could get it to work, but its not really the right application for this microserver. This was designed to be a home server vs a little gaming box. It has low profile expansion slots and a 150w psu. Not really an ideal base for a little gaming rig. You would be better off with a shuttle or something similar.
almost got it for a WHS but limited RAID, if it did 5 it would be perfect
These go for around $200 on fleabay all the time so don't sweat it if you miss out
DANGIT!!!!
I was waiting for this little server to come down in price again, I completely missed this :(
(sigh) mine is still in its sealed box. even bought extra ram for it. have no motivation to break it out and do something with it.
RAID 5 write hole is such a well documented problem that (I hope) most "real" RAID solutions already handle it correctly.
RAID 5 is designed to handle singular fault. Critical array + URE is double fault. If you want to handle double fault, go RAID 6.
A double fault is very likely in 2TB+ disks in RAID5/6.
By the time you RAID6 4 SATA disks I'd rather just stripe across mirrors w/ ZFS.
I have the older model with the neo 1.3ghz cpu in it running whs 2011. Put 5x 3TB drives in it. Runs great as an htpc with xbmc.
Oh yea...
http://www.flirc.tv/
Get that for it!
You're both right.
If you don't want to risk it just go for Raid 6 with 4 drives. That said it's pretty unlikely that 2 drives will fail close to one another unless they are both part of the same lot of drives that were defective.
