How tall is this monitor when on the desk? Is the 20.6" I've seen online correct?
Btw, guys, one question. 75Hz is only possible with freesync or is the monitor able to deliver 75Hz without it?
some of the posters here say with an NVidia card at 75hz you get frame skipping, and freesync is required to not have frame skipping. I've read people saying both ways. The guys that claim there is frame skipping with NVidia have put up pictures, the guys that claim there isn't have just said I don't see it. That's what I've seen anyway. I don't think I've seen a guy with an NVidia card who says there isn't, put up pictures of the blurbusters test showing there isn't.It will run 75Hz without freesync enabled.
Either way you can run the monitor at 60hz on an NVidia card with no problem --- I'm not sure which to believe with 75hz and a Nvidia monitor. Could be a setup issue, driver issue, unique PC issue whatever ---just throwing that info out there.
FWIW - I could notice the frame skipping with my 980ti @75hz while playing BF1. I also had issues where I would start to get a headache while using the monitor at 75hz. I may be more susceptible to motion issues as there's no way I can read in a car.
I decided to keep the monitor over my HP ZR30W because the colors are better. Running at 60hz I don't have any issues on the desktop or when playing BF1. Hopefully it's something that can be addressed, but only time will tell.
Really? Very interesting. Thanks for sharing that. I'm hoping to be able to do the same once I get a AMD card.I wanted to report in real quick to say I did some tinkering with the FreeSync range to see if I could extend it, since 48-75 is a pretty limited range. I heard issues about going above 75hz, so I instead opted to lower the bottom range using Custom Resolution Utility. I went as low as 30, but ran into brightness/flickering issues. I ran with a lower range of 40 for a while, which eliminated the flickering issues. I finally settled on 37-75 for one big reason: AMD's low framerate compensation (LFC). Although the recommended FreeSync range for LFC is atleast 2.5x the minimum value, only 2x is required for LFC to kick in, so 37-75 is enough to make it work. I can confirm that LFC kicks in when lowering the range from 48 to 37, and works as intended with frames being doubled when they drop below the minimum FreeSync value. I haven't noticed any issues with flickering with the minimum value set to 37, and everything appears to be working great. Having LFC working adds a huge extra feature to this monitor that I was missing from other high end FreeSync displays, and is very useful is some particularly graphic intensive games where dipping below 48 frames per second is common. I'm very happy with the results.
When you say you noticed frame skipping in BF1, what exactly did it look like? I'll have to keep an eye out for it to see if I also can notice it.
It has arrived!man it's big!!!
https://drive.google.com/open?id=0B46l6nboXvWgbXJVZl9XU3o5dklJdjA5cWJaY0JPOFg2VFU4
Any advices on calibration and settings?
How do i change from 60Hz to 75Hz, is it on the resolution windows settings or on monitor?
this, would be my perfect monitor. 32" 2560x1440 144Hz gsync. i dont get it, gaming monitor with 75Hz ???? I dont care if it is IPS or VA. Plz dear manufaturers: 2560x1440, 32", gsync and freesync variant. low input lag and low response time. i like my acer x34 and its the best monitor (also pg 348q) nowadays but i would immediately buy one of these. you get a good immersion because of the size and have no problems with games support (21:9) and have more than 100hz. i think many many people would buy such a monitor.
Well the 31.5'' Samsung CH711 might just going to be what you are looking for. We'll get detailed specs at CES in a few days.
Btw guys, do you have any banding on gradients? I know i know, i'm coming from an IPS panel but just to check( tried out with some fullscreen gradients and i see some minor banding )
I have banding as well across different spots on the monitor. This is more like DSE/Banding that gradient banding and mine is also really only visible on grey. I'd keep it man, both of mine have a bit of this and it's only noticeable sometimes. Enjoy the monitor...it's beautiful!I ordered an Omen 32 from HP Canada, and it arrived today. My Omen 32 seems to have no almost backlight bleed that is noticeable by eye, and which is basically only visible by taking a photo of the screen.
When I overclock the monitor, it overclocks fine (I tried 85hz), but the I get an on-screen message that says the monitor is exceeding its operational range, and will go into sleep-mode in 30 seconds. And in the message, there's a countdown timer, counting down from 30 seconds. Does anyone know how to override that message, and make it ignore the overclock? It's obviously an artificial measure HP put in.
Also, the monitor has some banding, and while it's not extreme, it's a bit distracting. In most situation it isn't visible. The exception is with grey, which is the only colour I've been able to notice it in, so far. Do any of these monitors have no colour-banding, whatsoever?
What do you people think: Should I RMA this monitor, and try for one with less banding?
