HP Omen 32" QHD Monitor - 2560x1440, 5ms, 75Hz freesync, VA panel
Decko87
Turn it off by going to a different (unsupported) mode on the monitor like Photo - then turn it back to Gaming- Freesync? Then make sure it is still set in the control panel?
Yeah it's all set, tried that, flat out does not work in FREESYNC mode. I switched back to 16.9.2 and it works. They dropped the ball a bit, new features are nice, but you can't break FreeSync.
Archaea
Well exercise SOMETHING with caution. I installed the relive drivers yesterday and didn't have trouble with that (freesync still worked for me) - but ever since installing the HP My Display and the HP Omen drivers about an hour ago I can't get an eyefinity game of Shadows of Mordor to launch. It crashes before it ever loads. I played it two hours ealier today without the HP monitor driver and HP My Display. I couldn't even apply bezel correction with the HP My Display software running. I had to turn it off. So I uninstalled it, set my bezel correction (since my eyefinity display had been lost due to the Display driver update assumably?) and now I can't get the game to launch at all?!?!
hmmmm...
Chewysc
The Black Levels on my Philips 4k where much butter than the Omen. Your exposures are different....has to be as I took the same pics.
Omen
Philips 4k 40"
You're probably right as I put my camera on AUTO everything. This time I put them side by side (for fun once again... something my wife doesn't quite get, lol!) and took some more pics for you all.
My Omen 32 on the left (Text Mode, 100 Brightness) and my Philips BDM4065UC on the right (Smart Uniformity Mode, 100 Brightness).
The Philips is definitely blacker however I do find it has blotchy patches of black shades (your pics above show it better than mine) where the Omen's black is very uniform and doesn't suffer at all from this.
There are definitely a few subjective nuances as well that you can see in person/with the naked eye that the camera doesn't pick up which makes me prefer the image of the Omen but they're all pretty minor.
"Both monitors are great overall!" pretty much sums it up for me.
Archaea
Got it working again after basically reinstalling drivers, discarding my eyefinity setup several times and recreating the eyefinity setup. I'm not sure what happened. It's like the HP software didn't like catalyst/relive driver eyefinity bezel correction. When I applied that all manner of mess broke loose.
Evil Scooter
The little HP Omen software is slick too! It works really good for me with three of these monitors because the buttons are otherwise hard to get too.
I can easily make adjustments to all three monitors and save the settings! Fantastic.
The software does not want to play with Win10 on my system, crashes. :(
Huacanacha
The HP monitor utility software also crashes for me on Win10. I installed the monitor driver as well... still skips frames at 75Hz.
I'm getting closer to deciding to return the screen. For my use I might as well get 4k 28" TN or a good 27" 1440p VA or IPS screen for around the same money. 32" is nice for gaming but the extra inches are no real benefit for work at 1440p resolution.
heftysmurf
In a weird way I am kinda looking for help.
I have the 29uc88 and the Omen and am having a hard time between the two.
29uc88
Tilt stand with height
Better contrast and colors (This kinda SHOCKS me)
Freesync is a setting you enable and not a mode you have to enter IE it is available in all color/pic modes
Practically use is gaming and split screen. Cannot see diving this up anymore.
Easier to drive resolution
Omen
SIZE- gigantic. Almost too tall in that I am having to move my head up to see the top.
Much greater usable resolution. 4 screen is a possibility but three seems very practical.
Color shift. I can see it if I put a nice pic as a wallpaper like a landscape one from Interfacelift.
If you move you head the hue will change.
USB ports!
The real problem I am having with the Omen is color and pop.
I have tried the Omen color file, the LG, The ultrawide dell icc profile, and manual config.
I cannot get the color anywhere near as nice as the LG.
If it looked at least 80% as good as the LG it would win in a walk.
The whole thing it is not. More like 50%.
So this leads to my questions for Omen users.
What color profiles and settings are you using particularly in Freesync/custom mode.
I want it to win because I love the real estate and can live with color shift and crappy stand but it is ugly in comparison to the L:G and really do not feel it should be this far off from it.
This whole thing with these two monitors made me understand why ultrawide 1440p is the sweet spot and also VERY expensive. I bought both these monitors for about the price of the cheapest 1440p ultrawide.
roaf85
The HP monitor software runs fine in Windows 10 for me however it offers no benefit other than the ability to save presets over just using the monitor controls.
roaf85
29uc88
Omen
USB ports!
To answer your question about settings I am on the last AMD Hotfix drivers. I think they are like 16.11.15 Crimson. I rolled back from the ReLive driver due to what I was experiencing as WoW issues. WoW kind of sucks anyways cause in the past when I was on the 280 and with the last expack (Warlords) I could never get AA to work without dropping tons of frames unless I used like CMAA or some shit.
Anyways I am using the ICC for Omen and you need to make sure in the Display Adapter it says Omen cause HP has a shitty thing of the installer will actually just unzip the files for drivers and in most cases there is an .exe that it will launch but with the monitor drivers I actually just manually added them.
I run AMD CCC color settings of -5 for Brightness, 92 for Saturation and 98 for Contrast. Then I run the default AMD FreeSync on the monitor for the obvious reasons.
I think the monitor is to bright and oversaturated at the AMD settings but isn't nothing deal breaking and to be honest aside from the newest ReLive drivers hasn't AMD or Windows always had a brightness/contrast and color setting?
That being said I struggle to believe that the LG 29 inch monitor has that good of characteristics. For one Ultra-wide is still an unproven format for a lot of reasons as FPS games do not want to support the 21:9 frame of reference and because of how webpages are formatted you really only gain an advantage if you want to place 2 windows side by side for comparing shit but at that point you have to do more vertical scrolling.
I do not see a color shift. I think most of you guys are actually just seeing a shift because the display is so big that it seems impossible to take in both sides of the back light without moving your head from side to side and this is magnified by the fact that the solid but shit stand places the monitor a "cock's" length up.
I am willing to bet if you place this on a 15 dollar monitor arm (by the way the stand is a lot of the weight) and pushed the monitor below eye level the contrast shifting would be better.
Finally there are a few of you comparing the BLB to a 600-700 Philips 40 inch 4k TV/monitor. This is basically trying to compare a semi nude to a full nude strip club. No comparison. Do we all expect this monitor to perform at Acer Predator levels? Or maybe it is just me but I went from a Dell 2005 FPW to a Asus MS238H and I thought the Asus despite it being a little bigger and LED was night and day over the 2005 FPW. BLB is awful it completely destroys the black scenes and some how people are content with exchanging monitors which to be honest is a nightmare.
You guys can dig up my post history where I had at one time 2 FPWs and was in college and Dell used to be ran by people who did advance exchanges. Now a days Dell can't even refund you for burnt popcorn.
I think the colors are better than my Asus by far and the response time and input lag I can not tell.
For 275 I know this monitor has workable quirks, but I honestly don't believe there is a better monitor out there for the price assuming you guys picked it up at this price 275-300. Unless the LG 29 inch ultrawide hits 200 I think its a no brianer to spend 40-50 to get a lot better workable resolution and to be honest a 2560x1440 is a lot less demanding of an increase from 2560x1080 vs going from 2560 to 3440 for an ultrawide 34 and you need a lot of wide screen real estate.
I also don't think anyone with Nvidia cards should be expecting much from FreeSync monitors to be honest. Sucks about the frame skipping but is there a cheaper 32 inch 2560 at 60 hz monitor?
Alright rant over, now back to HD pornhub.
heftysmurf
Thanks for the settings. I have not looked in ages and have now found they removed them and their are huge threads on AMD's forums about that UG.
You are right about hp having a lousy installer. Who tests these things?
if you want to count anybody surprised it was me on why the LG looks much better.
I had that first said wow the Omen looks nice and only 25 bucks more and MUCH bigger. Its like putting a 4 inch topper on the LG.
Gaming has been no issue at 21:9. Most my games work and if not I could care less about black bars.
I have used at least 5 different color profiles and a crazy amount of tweaking and cannot get that pop look of colors or that vibrancy the LG has.
You are right about the aspect. Really a two/ 1.5 window display. Being about the same width pixel size it is odd one page feels OK on the Omen. One looks very odd on the LG.
The color shift is real. I am currently using "The birthplace of rivendell" from Interfacelift. If you look at the trees in the foreground and move you head while looking at the trees in the foreground you will see the green change. Head on perfect looks rich and contrasty move head left or right (still in front of monitor approx 30 inches away) and they will lighten up on the sides. I am kinda miffed by it and think it must use a different VA than what my ancient Dell 2407 has.
I feel like the Omen is a great monitor for the price despite some kinda big flaws. You are not going to get a bigger monitor for the price.
The LG 29 (which I 100% expected to lose to the omen) has better contrast (still cannot believe this) better viewing angles and is sharper.
I want to get the Omen to the point it looks at good and I cannot.
I am going to tweak it again tonight and see where I get.
I would call them equivalent in different ways and it boils down to this.
Image quality LG
Size Omen.
Archaea
Link the specific picture you say has color shift.
I have three of these Omen monitors and I notice no such thing and have taken pictures to show it doesn't have noticeable color shift and posted them here. I had a friend over recently and asked him if he saw color shift and he said no. He also volunteered there was no backlight bleed in person. Coincidence that it is. He also has the LG 34" widescreen. Another friend also has the same LG 34" panel. I played on it at the last LAN a bit and while it is also a nice monitor there is now way I'd say either has way better image quality than the next. Of course my experiences are anecdotal, as are yours.
heftysmurf
Their are many.
Now I want to hold back as the Omen is a good display no doubt but however stunned that the LG's seem better in some ways. Omen in others.
Take a look at this pic.
http://interfacelift.com/wallpaper/D45410bb/04086_queenstownfrombobspeak_2560x1440.jpg
Make it your wallpaper.
Now stay in front of your screen and take a look at the tallest trees in the foreground on the left. Move you head 6 inches left or right but stay in front of the screen. Look at the color of the trees. You will see a shift where the trees get lighter and darker.
I cannot get the LG or my ancient 2407 to do it with the exact same pic at native rez on all of them.
Do I think this is a deal breaker for most uses? No.
If I was doing color critical work no way.
The Omen is a definitely a plus on backlight bleed. None at all. Black is black :)
Lg has some in upper right corner which is common with 29uc99. Un-noticeable in use at all.
I would pay extra for the HP Omen to be color calibrated out of the box and have the ability to use freesync as a setting not a mode.
That to me is the biggest issue with the omen.
Your buddies with the LG UW can be in photo mode and have freesync on.
I still in a way think UW 1440p is a total ripoff.
I have the Omen and the LG29 and they both combined cost less than the cheapest UW.
Your triple setup is equal to ONE of the 34uc88 UW in cost.
The new Samsung which I think will be the best of them all is 1K. WOW.
With HDR/ dolby vision/ advances in hz around the corner I view whichever one I think will not get a run like my 2407wfp.
I view this a two year plan where I will get another. I just will not pat 1k for a nice UW when I get get this for so much less.
Just hoping I can find a few more image tweaks to make my Omen a home run as I can live with some flaws but the color is big to me.
Archaea
Unless your eyes are way different than mine I don't see any color shift. I'm moving my head around like some sort of rockstar cockatoo.
(see this video at 30 seconds for a visualization of me right now --
and I see none. Here are some camera pics from different angles.
Way more than six inches covered here...
retaking pics because the LED reflection from my keyboard is showing up.
cmacclel
Unless your eyes are better than mine I don't see any color shift. Here are some screenprints from different angles.
Maybe some peoples eyes are not as sensitive to the color shift. It was the first thing I noticed once putting the Omen on my desk. I even called my 16 yo son in and he saw it right away as well. I know have a Dell G-Sync 27 144hz in front of me and although it looks like crap it has no color shift I can see :)
heftysmurf
I still think the Omen is awesome because IMHO their is no better deal for a big screen right now that is a real monitor.
The picture even with the shift destroys my old Dell and my laptop by 10X.
I wish I did not see it and I still dont know if color shift is a deal breaker because see above.
I may see more issues than some with the Omen but your setup Archaea IMHO is sick as hell :)
Decko87
I actually see what you're saying heftysmurf, I thought that was black crush though, the brightness of the colors increases when i move my head vs. when i look dead on? I can see more detail in the trees with my head to the side vs. dead on. It's slight, but I can see what you're saying. Minor complain honestly, this thing looks fantastic, easily a great hold over until HDR 144hz 4k.
TophSmash
Everything gets whiter at bad angles.
If you are 3+feet away from the monitor the color shift is impossible to see without getting out of/moving your chair.
At 2 feet you have to move your head half the length of the monitor to see it.
Imo its a non-issue.
As for color accuracy, the issue is there is no hardware color gamma setting. Just gotta wait for someone to color calibrate these things.
Decko87
I hope someone with a professional calibrator does it at some point. This thing isn't very well advertised, I'd be surprised if it's that popular.
Daffan
I'm still waiting for pro information on response time and input lag.
All this hubba bubba about PQ and none about gaming performance!!!
heftysmurf
Good feedback and discussion everybody.
The Omen has issues and is great despite them.
Getting the 29uc 1st (uw) and the (high res) Omen 2nd has made me understand a lot.
Despite the smaller size the 29 is definitely more immersive and that I think is a function of height.
It is more comfortable to have shorter monitor near your face.
The triple Omen setup is the cats meow as that gets by the issue of lack of immersion because even back your peripheral would have some data.
I think that is a better bet than a 1440p ultrawide at this time and costs the same.
The Omen is so tall that you need to push it back.
Freesync works great on both.
I was able to increase picture quality a good bit by bumping the color up to 7K. Made a world of difference.
I so understand why UW 1440p 34 is totally the sweet spot.
Less height same rez as Omen and it fills the sides.
Cost is stupid right now and not at all worth it IMHO especially with DP 1.4/ HDR/ higher refresh rates coming.
I notcied a few other things that are great and not.
1440p is cool and not at the sametime.
Cool - windows workspace.
Not. You may be at 16x9 playing a 1080p video stream HOWEVER you are scaling and to me that looks cruddy.
I am seeing if with the Omen you can cheat and have the best of both worlds.
CRU will let you set a 2560x1080 res at 60 HZ (will allow 75 too) and freesync works.
I beat Doom 2016 last night set to UW rez and it looked cool having the wide FOV and having the monitor closer but man my eyes hurt.
Onto more setup testing.
roaf85
Hefty etc.
I understand what you guys are saying but you have to realize something.
1. I don't personally have a desk wider than the thickness of my dad bod so literally 32 inch is the max. 34 inch ultra wide is going to be way too wide without relocation the speakers. Granted I could hang either option on the wall. So yes some people I think are buying this due to desk space but that is a minor thing however
2. A 34 inch is 3 inches wider and 3 inches shorter so pick your poison. The 32 inch 1440P option falls somewhere in the middle because the 32 option is still way more real estate than a 250 dollar LG 29 inch ultrawide
3. I don't believe the LG is without fault. I have yet to see any consistency even with LED on IPS panels. Backlight glow/bleed is a real thing on most IPS panels and I don't think people realize that they are intrigued by colors which they can adjust but they never can get rid of the glow in pitch black images.
4. This monitor doesn't upscale 1080p movies and if it did it just has the same pixel density of a 23-24 inch 1080p monitor which is a decently popular size for 1080p. So yea while pictures may be in your face they are actually bigger and you don't have to worry about any DPI settings.
5. Even if ultrawide becomes more of a standard and say it is supported in the professional gaming realm you will always have developers struggling with supporting an increased frame of view due to any competitive advantage and I am talking real competitive advantage now what you have by having more DPIs on a mouse or some other shit that you can tweak on your existing mouse.
Archaea
All three of mine are excellent - I'm not selling but my product dates are all June 2016 (happenstance --- one was purchased a few months ago from HP directly, and two were purchased over Black Friday from Amazon).
So i finally received my omen, set it up today (upgraded GPU to a Radeon R9 Fury).
First thoughts. Huge. Tons of space to work with.
Still need to test for a a few days thought, but something i noticed and wanted to ask here.
I wear computer glasses when i work as i spend a lot of time in front of the monitor. They are not corrective, but relax my eyes and help them with fatigue.
Anyway, i noticed that when looking at text with my glasses on, i can see like a black border around the text itself. Does not matter if it is a website, application, code or game, it is very obvious and noticeable. Never saw that on my previous monitor.
Any thoughts on what that could be?
Also, when looking direct center at the monitor, i can see some 'darkness' on the left an right sides of the screen. If i look directly at that section, goes away.
Thx
Decko87
Thx
Try running through the windows calibration and cleartype, I had some issues with the text before I did this. In terms of darkness, yeah it might look a little different depending on where your head is located because the monitor is so massive.
Decko87
Has anyone tried using this monitor on a different VESA stand? I'd like to be able to tilt this thing past 90 degrees, but i'm not really sure what type of stand to buy?
Archmage
I have the HP Omen 32 mounted on an Ergotron LX articulating arm + extension, clamped to the desk. This is way bigger than Ergotron spec'ed for the arm, but it's still working fine.
Daffan
Estimated response time and input lag guys?
Only Archaea ever talked about it, but only roughly in a video.
MTRougeau
Input Lag is noticeably higher than 144hz TN and IPS panels, but it's not terrible. For hardcore twitch gamers playing CS:GO or Dota, it could be a problem. For most other uses, including single player games or controller based games, it's not going to be an issue. Plenty of Fallout 4 and Rocket League from me on this monitor, and it's great. Response time is respectable for a VA panel, and is decent enough, though dark transitions will definitely exhibit some ghosting/trailing. Overall, the good greatly outweighs the bad. Blacks are rich and deep and the size of the screen is awesome for gaming. Throw in FreeSync and you have a heck of a monitor.
Archaea
noticeably higher for you?
I've used this and a 144Hz Acer XZ350CU (FreeSync version of the Predator X) back to back and I can't feel any difference on input lag. I couldn't on the Dell 3014 either. I play at 6-15 person LAN parties about every month or two and I've not had any problem switching between any of these monitors and either securing top slot on the leaderboard or being top three in any twitch first person shooter games including Battlefield, Doom, and Overwatch. I notice absolutely no input lag on my Omen displays with the Fury X cards (I haven't tested with Nvida, but I don't think that should matter, unless you are experiencing frame skipping trying to run the Omen at 75hz with an Nvidia card). That's only speaking for me. But I guess I just wonder when people say you shouldnt consider a certain monitor if you are a hardcore gamer. What exactly is a hardcore gamer? It's like superfluous advice. I don't know any hardcore gamers. Are we talking someone like fatal1ty or subzer0? For real world consumers can anyone really tell the difference in current monitor tech? When I used a 37" Samsung HDTV for a short time a few years back I did notice a slight bit of input lag and it wasn't bearable, but when I used a 32" HTDV from Toshiba the input lag was perhaps very slight but bearable to me (for reference). The input lag on the Omen is not even observable to my eyes/senses - whatever actual MS rating it is. Perhaps perceptions on that are different.
MaStA819
Do you mind sharing all of your monitor settings with us? Thank you!
Archaea
I'm not a photo editor and I don't have a calibration tool. I primarily game on my displays. So I quite simply put them all in gaming freesync mode and turned the brightness down to 50 on each. That's it. Works for me. The photo and text settings might look a bit more accurate - but I don't really care that much. It's pretty darn good on the gaming freesync IMO. I have a friend that just bought a monitor calibration tool. I've asked him if he would come by and calibrate one of my monitors. he said he would --- maybe after the holidays. When he does this - I'll share for sure.
MaStA819
That would be great! I was mostly curious about your sharpness and response time settings, but if you leave them default that is irrelevant. :D
I look forward to seeing what the calibration tool comes up with for more detailed settings. I appreciate all of your help!
MTRougeau
Yes, noticeably higher for me when tested again my Acer XF270HU IPS display. Even when on the desktop there is perceptible lag when moving the mouse compared to other high end gaming monitors. This small difference in input lag can be a big deal in competitive shooters like CS:GO. You can also objectively test for higher input lag between two different monitors at this site: http://tft.vanity.dk/inputlag.html. I noticed it was consistently about 15ms behind my Acer. So, the difference is there, though it may not be as noticeable to some people. (I'm on a 290, btw.)
Daffan
Interesting comments here about the input lag and response times guys.
I'm from AUS so jumping in on a buy takes more investment.
Love the idea of 32" 1440p been looking for ages. Currently on a 28" 4k and it's excellent but always wanted 32" since I used a 32" HDTV back in the day.
GenesisX
Purchased one from HP Australia about a month ago, cost $799 but you get around $100 back from cashrewards and giftcards (very jealous of the $299 price you americans get!!!)
Awesome monitor, coming from a Acer X34 I was surprised how well the HP stacked up, the lack of glow or BLB makes a big difference IMO.
I have calibrated it using a old colourmunki, will upload ICC profile later.
  • OMEN by HP 32_D65_201612201923.zip
MaStA819
Awesome! Thanks!
Decko87
What was the issue with the Acer? Also, that would be amazing if you hooked us up with the ICC profile.
GenesisX
ICC uploaded, see my first post above. I just used the colormunki smile software so hopefully its decent. Can try again with displaycal if you guys have more experience with using these software.
No real issue with the Acer, just the glow started bugging me after a while. Especially in movies and content that weren't in 21:9 :/
EDIT - Forgot to mention, freesync mode. Brightness set to 60.
Archaea
I ordered an Omen 32 from HP Canada, and it arrived today. My Omen 32 seems to have no almost backlight bleed that is noticeable by eye, and which is basically only visible by taking a photo of the screen.
When I overclock the monitor, it overclocks fine (I tried 85hz), but the I get an on-screen message that says the monitor is exceeding its operational range, and will go into sleep-mode in 30 seconds. And in the message, there's a countdown timer, counting down from 30 seconds. Does anyone know how to override that message, and make it ignore the overclock? It's obviously an artificial measure HP put in.
Also, the monitor has some banding, and while it's not extreme, it's a bit distracting. In most situation it isn't visible. The exception is with grey, which is the only colour I've been able to notice it in, so far. Do any of these monitors have no colour-banding, whatsoever?
What do you people think: Should I RMA this monitor, and try for one with less banding?
My thought on this kind of thing is if you have to try to find a flaw and it doesn't hit you in the face 99.9% of the time when you use it --- who cares. I personally wouldn't send that back. Maybe try adjusting your brightness settings and see if that band in the gray goes away. I suspect it's more noticeable in the picture than to the eye. If that's the case -- who cares. If it's something that really bugs you and you can't unsee it then you can RMA it. Seeking out problems in life doesn't make any sense to me.
