It's not specific characters, just more noticeable for some. I did get a little better text sharpness at higher brightness levels. I'll play around with settings some more before deciding whether I can live with it. A scan of the monitor market shows 4K options are only reasonable in ~$400 price range for 28" TN panels... there are some decent ones but not sure I want to go TN.That would probably help, but if you are hung up a specific character like a T, why not try to change the default font that windows uses for menus and text? Just curious?
Except it's advertised as a 75Hz monitor and even bundled in HP systems with Nvidia GPU's. The product page doesn't say 75Hz is for AMD Freesync only. It's still a good deal for ~$300 and a nice 60Hz monitor but the fact is it can't meet it's stated specs for the majority of GPU's in the wild.
are you using free sync? You have to turn it on in the crimson driver panel under display, and you have to turn it on with your monitor initially by turning it to quick setting gaming-freesync. (you can then modify that setting which becomes custom --- so subsequently you can use gaming-freesync or custom)Does anyone else have issues with display port detection? I have to have it set to always on.
Also does anyone else have vertical screen tearing? It happens in game and out.
I'm thinking I have a bad cable or a bad displayport port.
That should rid tearing if you have a 2xx series AMD card or newer.
If you have a Nvidia card it seems you'll have to run this display at 60hz to avoid frame skipping which may amount to looking like tearing.
I have three of them and they all turn on normally (from display port signal) and go to power save mode when I turn off my PC. All three of them are on display port cables from my Fury X card which has three display ports and 1 HDMI port.
Didn't notice this before.
In the on screen display under Input Control>DP Hot-Plug Detection do you have them all set to low power or always on?
just checked
default = low power
I never changed that.
Gotta love Amazon, the one I actually played with that had BLB and banding I setup for a return I get credited as soon as UPS took it away. The other 2 that arrived almost a week late that I refused delivery of (Amazon said to) I'm still waiting for a refund a week later. They say 3 business days after they receive them back. Make sense right.....NOT!
How bad was the banding on yours? I had one that seemed pretty bad and one that doesn't seem to have it.
It disappointed me enough I didn't want to open the other 2After seeing the triple setup Archaea posted I'm jealous
here's a few more pics![]()
I am just curious and you know asking for a friend. Does pornhub stretch across in Eyefinity or are web applications limited to one screen? Cause if it works with Eyefinity, I might have 2 more on order.
2nd monitor arrived, no idea how bad this is:
https://drive.google.com/open?id=0B9Tj2tGKb4PaOXZ6UVlhTVZPdzZxUmFDNlJqSjZJZEtweFUw
https://drive.google.com/open?id=0B9Tj2tGKb4PabVBjZmFnMnQyTXZEcjQ2a1lqTG94TXlacXJN
I honestly don't think this is that bad, but I just wonder how everyone is able to perceive the full screen anyways unless they are sitting like 5 feet back. 32 inches is so big that I have a issue with viewing angles just looking straight on because my eyes have to shift around the screen so much.
Still is sweet. I am in love.
One of the reasons I returned mine is exactly what you said. I also had a viewing angle color shift problem with the monitor 30" away from me where my 40" Philips 4k has no viewing able problems 34" away from me.
Can you elaborate on your viewing angle problem? Maybe provide a camera photo or three from different angles? I have pretty much NO color shift and my display is 80" across as shown above in post 229. both you and cmacclel have mentioned color shift - I find that odd in comparison to my lack of such in my experience. The colors stay very true on my setup - even with three of these Omens. There is no noticeable shift in colors even from way off vantage points as I tried to illustrate in my photos ---notice the colors look the same regardless of angle in post 229.I am not sure how to prevent that other than going smaller, or mounting the monitor to the wall which is what I am probably going to do.
Just wanted to let folks know that the two monitors I received were from October 2016 and September 2016. Both had issues although the October panel seemed to have worse issues including banding whereas the September one only had BLB.
Are you asking for pussy?
I have an Oct build and have virtual zero backlight bleed. I really don't think there is a panel lottery to be honest.
For fun, I hooked up my Philips 40" 4K monitor and took black screen shots to see how it compares to my new Omen 32, Sept build. The results are pretty astounding...
Videos will have black bars in eyefinity.I am seriously curious if you can stretch videos across Eyefinity
I have the latest drivers installed, Freesync is enable on my monitor and in the drivers. FRTC set to 74 FPS, freesync does not work anymore. I've tried setting the target lower, I get tearing in rocket league. I get tearing in Witcher 3 where i'm dead center in my range (around 60 fps). My monitor is the HP Omen 32 inch, it's a range of 48-75 fps. Any suggestions? I'm hooked up with display port, and I've tried different cables to no avail. Going to downgrade my drivers.
