Mayseffect
- Apr 11, 2017
I'm not understanding this. It only enables itself when a application such as a game triggers it?You can only use the freesync in quick view setting "Gaming-Freesync", or "Custom" mode if you modify "Gaming-FreeSync mode. If in anyother mode you can't select Freesync. Yes your 295 should be compatible with freesync.
What do i have to modify? I see that it has selected its native refresh rate to 75hz 1440p but the information tab for the monitor shows its set at 60hz.
