Archaea
- Oct 19, 2004
How do you lower the freesync range?
Thx, i'll be back later with an hardware profile.Suggestion. Try to calibrate it without profile. Use the Munki + HCFR for measuring results. It is far preferable to have a display calibrated from its own hardware settings than using calibration software to make profiles. Since profiles are not always respected by some full screen apps or games.
So if i own a 980Ti I should skip this monitor if I'm looking for 75Hz without Frame-Skip?
NVidia users: I have spoken to someone from NVidia. Upload a DispDiag log file so I can forward to them. http://nvidia.custhelp.com/app/answers/detail/a_id/3468/
As of right now, Yes. I still have skipping at 75Hz, hopefully Racerprose will have some good news for us NVIDIA users.
There is also a thread over at HP's support forums. I'm hoping someone from HP responds about the NVIDIA 75Hz issue.
http://h30434.www3.hp.com/t5/Gaming-Accessories/Hp-Omen-32-inch-monitor-frame-skipping/td-p/5948231
I have not sent the file in. Figured Racerprose was operating under a case# number with Nvidia that has all the context of the issue.Have you forwarded the uploaded DispDiag file? If not, does some else want to? The NVIDIA support email is listed in the link. [email protected]
I have read the whole forum, but now that there's some time under the belt with this monitor. Would people still suggest this monitor? or move along? The 32" size for immersion sounds amazing, but not owning a AMD graphics card for 75hz, and the thought that you can grab an asus 27 1440p 144hz for the same prices makes me wonder.
I picked up this monitor over the holidays and I love it, but I've been getting pretty bad eye strain. My previous monitor was a 8-year old 27" samsung LCD and I could stare at that thing for days with no problems. I do a few hour gaming session on this monitor and the next day I'm in pain.
I've tried varying brightness, contrast, warmer color settings, and using computer glasses, but nothing seems to help. I called HP tech support and they seemed concerned but offered no real help either. They couldn't tell me whether the monitor uses PWM or not. I've tried to do a couple of flicker tests myself and can't see any signs of PWM so maybe that's not the issue.
Anybody else having similar issues or can offer any recommendations? I have pretty sensitive eyes so I wouldn't be surprised if most people aren't.
Thanks!
No eyestrain here. Been using it since August. I still really enjoy mine. I agree that 27" at 1440p is not as enjoyable. I had one of those Korean 27" ips monitors and sold it within two weeks. For me the text was too small on the 27" 1440p.
As to eyestrain have you tried varying seating distance with brightness lowered quite a bit? I'd guess you are too close and it's too bright.
Maybe also make sure you are using 60 hz if nvidia user. I run mine at 75hz with freesync on an AMD card.
Yeah this monitor is like staring into the sun at higher brightness levels.I had eyestrain the first day with the new monitor... Had to turn the brightness down to 45 to eliminate the eye strain.
Ok...so I picked this monitor up on eBay (refurb, didn't come w/ VESA mount nor the DP cable but eh). My question is: Do I REALLY need to use DP for Freesync or since I am running the latest Crimson Reborn drivers (17.2.1) I can skate by with HDMI? (If I overlooked it in this thread then I'm sorry)
Archaea as far as resolution that can be done via HDMI (as I'm currently at that res @ 75hz...unless I'm still cheating myself LOL).
Face2Face: As far as I can tell: no image issues. Everything seems sturdy EXCEPT the buttons on the back. Some feel like they're starting to stick or they don't click properly. This may be by design. Other than that the monitor's great! Dropped the brightness down to 50 and changed the color values as was posted in this thread. I can't tell per say if Freesync is running or not over HDMI. The monitor says it's on and so does the AMD control panel...
No dead pixels and at least on mine I don't notice any back light bleed. I just have to get used to a 32" screen (coming from 24" WS + 19" ... normal...screen?). Getting this monitor at the refurb price (I paid 275 from the same seller as yours) or heck even if you can get it for under 350, it's a great monitor.
I may pick up a DP cable. Could go to Best Buy and get one but...no...no Turbo...you know better than that.
yes, full resolution via either hdmi portcan anyone with this monitor test if you can get full resolution with HDMI? I don't care if it's only 60hz. thanks
Does anyone know how to turn off Dynamic contrast off and keep it off? Every time I turn the monitor off and back on again, it becomes enabled. I like the look of it, but it's killing my eyes. I have the brightness down to 24ish and with Dynamic contrast on it goes back to being too bright.
Thanks!
Are you still getting eye strain? I'm having the same problem. Like you, I love the monitor but it's killing my eyes. I tried all of the things you have and I'm not sure what to do at this point. When I go back to my 27" qnix I can feel my eyes start to relax persay. It's an odd feeling.
For those interested, here are my calibrated settings for my Omen 32 using a Colormunki Display and DisplayCal.
Custom Mode for Gaming (w/ Freesync) Settings Feb 26:
Color Temp @ 6500K
Brightness @ 32 (109-110 cd/m2)
Contrast @ 80
R @ 252
G @ 255
B @ 240
If any of you would like my built ICC profile that took over 4 hours to do, let me know and I'll upload it.
Cheers!
