HP LP2475w (Possible new IPS)
Discussion in 'Displays' started by worthless808, Jul 18, 2008.
  1. philjohn
    philjohn Limp Gawd
    261
    Apr 1, 2008
    It's a brand new panel part for 2008 from LG.Display, I would suspect it's H-IPS.
  2. ShadowFusion
    ShadowFusion n00b
    21
    May 22, 2008
    Input select problem
    I've narrowed it down to my comp's Vista/drivers and only affects DVI (not VGA). It doesn't matter what other inputs are present. If I leave the [digital]DVI input source, I cannot return without restarting.
    Paused in BIOS and switched source: Works fine
    Booted into Vista and switched source: not fine
    It doesn't matter if I auto or manual change
    Graphics card: ATI Radeon X1300
    Thanks for the help! Hopefully I wont have to use VGA :(
    Update: Fixed, updated driver... ahh so simple :p, it was hiding away in Vista's "optional" updates
    360 and games
    It looks great, no humanly noticeable lag at all, colors are great when set to "Custom RGB mode" but can easily be adjusted.
    Yes, COD4 looks and plays perfectly, as do all my other games
    Yes... wait, what! no! :p
    Yup, though it has a custom holding slot that you simply unscrew I think.
  3. philjohn
    philjohn Limp Gawd
    261
    Apr 1, 2008
    Just tested here with my Vista x64 machine and a Mac Mini (both via DVI). Input switching works fine, the Vista box comes back on no problem. Vista is using an NVidia 8600GT and the Mac Mini is a G4 era one with a discrete ATI Radeon card 9200 chip.
  4. hektorrr
    hektorrr n00b
    11
    Aug 26, 2008
    Actually its crucial what type of panel that lcd got for me cause i`m going to buy LP2475W only for H-IPS. If it got S-IPS i buying HZ24Wi.
  5. ShadowFusion
    ShadowFusion n00b
    21
    May 22, 2008
    ok, I now only have glowing recommendations for this monitor.
    It's the perfect all-round 24" a lot of people have been waiting for.
    It's not perfect in everything, but it gets 8.5s and 9s in all areas from me (except for the stand (7) :p)
    Let me know if you have any questions, I'll do my best :D
  6. ashmedai
    ashmedai [H]ardForum Junkie
    12,403
    Feb 26, 2005
    Mostly waiting on an objective measurement of input lag, here. Confirmation of cell type would be nice too.
  7. Deathray
    Deathray n00b
    54
    Aug 31, 2008
    Can any of you confirm that the input lag is around 19 ms?
    Also, how is the ghosting
    Anything fixed about this?
  8. ShadowFusion
    ShadowFusion n00b
    21
    May 22, 2008
  9. ashmedai
    12,403
    Feb 26, 2005
    Hmm...there are an awful lot of 31s in that list.
  10. 10e
    10e 2[H]4U
    3,383
    Jul 20, 2006
    Don't bother with that. It's already been done and the results are unquestionably good.
    This monitor is a winner and you are another happy user here, which bodes well.
    I'm assuming your Xbox 360 image has some black bands top and bottom of the image display if the monitor is in aspect or 1:1 mode correct?
    Glad you got the video card driver stuff sorted out.
    Congrats and enjoy!!!!
  11. 10e
    10e 2[H]4U
    3,383
    Jul 20, 2006
    Why is this important?
    I believe the pixel structure is the same, and other than the A-TW polarizer, you get all the same excellent characteristics, backlight which adjusts down quite well, and great viewing angles other than the off-angle white glow, which likely indicates a similar panel to all older H-IPS displays, as older S-IPS models have violet off-angle glows.
    It can't be the same panel as the NEC 24" because it is a newer model with wide gamut, and realistically H-IPS and S-IPS are (for the most part) primarily interchangeable.
    I seriously think you would be short changing yourself if you didn't give this monitor strong scrutiny and consideration.
    We have a number of HP (S-IPS) screens at work that are all still going strong after three years of use and look fabulous. None of them has a single dead pixel or sub-pixel.
    Additionally, the Hazro is glossy while this is not. While this can bump up clarity a small amount due to no anti-glare, it's a disaster in a well lit room.
  12. Drags
    Drags Gawd
    941
    Apr 26, 2005
    can someone take a pix of the pixel structure?
    here is the one i took (sorry, was changing the link)
    [​IMG]
  13. hektorrr
    hektorrr n00b
    11
    Aug 26, 2008
    Some people who have Hazro HZ24Wi which is with glossy screen are telling text look better than opposite (HZ24W). Just take a look on S-IPS and H-IPS screen.
    [​IMG]
    ShadowFusion could you tell how text look on your screen is it sharp enough for you, is it better then your previous lcd or just the same? Could you do macro picture of your screen?
  14. 10e
    10e 2[H]4U
    3,383
    Jul 20, 2006
    That's pretty weird.
    It looks like it has yellow, magenta and cyan pixels too? This is strange. Does your camera have a super macro or macro mode at all? It's usually the "flower" icon on it.
    Here's an example of pixel structure of H-IPS and A-MVA. BenQ FP241VW (A-MVA) on the left, and NEC (H-IPS) on the right:
    [​IMG]
    If you notice, the H-IPS of the NEC has a slight offset between pixels side-by-side and a larger space between pixel sets top and bottom causing the slight mid-grey aberration of slight horizontal lines that ToastyX has mentioned as a characteristic (and I see when I'm looking for it).
    The blending effect is primarily a *VA characteristic. I don't ever remember seeing it on S-IPS or H-IPS. Both have very sharp text.
  15. ashmedai
    12,403
    Feb 26, 2005
    Mostly concerned with pixel structure due to the blending effect that occurs in some configurations. It's my understanding that H-IPS gives a significantly improved result for text etc over some implementations of IPS.
  16. Moogle Stiltzkin
    Moogle Stiltzkin Gawd
    814
    Nov 11, 2004
    So uh..... who are we to believe ? HP site that says S-IPS or TFTCentral thats says
    it doesn't really matter which was long as it's either S-IPS or better yet H-IPS. Only the results matter :D
  17. ShadowFusion
    ShadowFusion n00b
    21
    May 22, 2008
    My best guess would be the straight pixels. The text looks very sharp, at least as good as the 2007WFP, what ever structure that had.
  18. ashmedai
    12,403
    Feb 26, 2005
    Again, listing S-IPS doesn't necessarily mean anything. It can mean S-IPS, or it can be a blanket name for many of the x-IPS versions like H-IPS.
  19. 10e
    10e 2[H]4U
    3,383
    Jul 20, 2006
    The 2007WFP was S-IPS or S-PVA, but the text is very sharp with S-IPS. It has the same exact panel (for S-IPS) as my 2005FPW which has extremely sharp text.
    In regards to the HP there is definitely CMY pixels in that shot, but they are all lit (????) so that is pretty weird. I'm sure it has some use.
    Craziness.
    H-IPS is an evolution of S-IPS:
    The pros/cons of the H-IPS over the S-IPS from Wikipedia.org @ http://en.wikipedia.org/wiki/H-IPS
    Pros:
    * Much less backlight bleed.
    * No purple hue visible at an angle
    * Backlight bleed improves looking at an angle
    * Less noise or glitter seen on the panel surface (smoother surface)
    Cons:
    * Still some backlight bleed in areas that are green.
    * Viewing angle is narrower.
  20. ShadowFusion
    ShadowFusion n00b
    21
    May 22, 2008
    I've got the IPS version ;)
  21. Drags
    Drags Gawd
    941
    Apr 26, 2005
    the screen also shows the white hue when viewing an all black screen from an angle, suggesting H-IPS rather than S-IPS (which is normally a purple hue).
    pixel orientation certainly looks like H-IPS, but confused over the different colour sub pixels. I took those on my camera using the macro "flower" mode on an all white background.
    edit: given it's LG.Display's latest panel as well, it's likely to be H-IPS since they have kind of migrated to that now from S-IPS structure
  22. ashmedai
    12,403
    Feb 26, 2005
    Sounds like a reasonable litmus test for the time being.
    Were you referring to the Dell panel lottery shenanigans, or is this with respect to the HP?
    Do you see the purple glow at steep angles? I think someone had a pic of what this should look like a few pages back, but I don't recall anyone responding re: the HP since the thread got derailed onto that UK-only monitor.
    Sorry, the interest in this thread is leading to lots of interleaved posts. :D
    The lack of purple glow definately indicates H-IPS and agrees with the TFT Central data. The shot you took, though...I don't think your camera is really suited to this. I think it clearly shows S-IPS of some sort, but not enough to show H-IPS without the lack of glow to confirm.
  23. Drags
    Drags Gawd
    941
    Apr 26, 2005
    def a white hue here, indicating H-IPS and lack of A-TW polarizer afaik
  24. ashmedai
    12,403
    Feb 26, 2005
    Bingo on both accounts.
  25. Rendition
    Rendition n00b
    55
    Aug 3, 2006
    I talked to HP customer service rep. He couldn't confirm the USA version was an IPS panel. He is it is most likely the same panel as the foreign monitors. I think I'm going to wait.
    The HP UK site says as a key feature: "S-IPS panel and 92% gamut"
    The HP USA site says "TFT and 102% gamut". I mean it's most likely a typo, but I mean HP, this is pathetic. Get your info RIGHT!
    I mean there were instances of previous monitors where manufacturers use different PVA and IPS panels at different times for the same model monitor in different geographies.
  26. samven582
    samven582 Limp Gawd
    299
    Apr 1, 2006
    so this monitor is now H-IPS ?
  27. ashmedai
    12,403
    Feb 26, 2005
    I'm sorry, but does the ignorance of customer service reps really surprise you? It's meaningless that some college kid with a call center job doesn't know intimate details about the technology.
    You get it right. TFT and S-IPS are both correct ways to refer to an H-IPS display. Of course, TFT doesn't tell you jack shit...H-IPS is a type of S-IPS which is in turn a type of TFT.
    We've got multiple confirmation from a number of long-time forum members. It's about as sure as it's going to be without an extensive review from someone like ToastyX - which doesn't happen for every monitor.
  28. deadman3000
    deadman3000 [H]Lite
    69
    May 13, 2008
    Super Macro mode on my Canon S2 IS. I'd say it's H-IPS.
    [​IMG]
    EDIT: Sorry for the eyestrain. It hurts mine!
  29. ashmedai
    12,403
    Feb 26, 2005
    Now you have a nicer camera for this stuff. :D
    Also - yes, OW!!!
    FYI, Live Cashback has an entry for HP Home & Home Office. The display is listed as a business product, but you might be able to swing a $32.50 rebate if you enter through Live.com.
  30. ashmedai
    12,403
    Feb 26, 2005
    Um...silver or black bezel? They have conflicting pics.
  31. 10e
    10e 2[H]4U
    3,383
    Jul 20, 2006
    Big thanks,
    Gotta love the S<x> IS series. Mine is the S3 IS. I wanted the S2 for a long time.
    Nice job and that is exactly H-IPS pixel structure.
  32. deadman3000
    deadman3000 [H]Lite
    69
    May 13, 2008
    One thing I have noticed is that there is a brightness uniformity issue on my panel. The right hand side is definitely slightly duller than the left hand. It's only noticeable during solid colour testing. Could this just be a problem with the CCFL on that side? I would not have noticed it had I not done the macro shot on a solid white screen.
    EDIT: Hmm. Now I am not so sure. Just checked again and it may just be the edge of the screen and down to viewing angle. It looks worse at some angles. Maybe I am just being picky :) I don't see it at all in normal viewing and no bad or stuck pixels either.
  33. Deathray
    Deathray n00b
    54
    Aug 31, 2008
    Anyone have an idea of when this is coming to Canada?
    Provantage can ship to Canada, but I'll probably run into customs and then i get burned...
  34. philjohn
    philjohn Limp Gawd
    261
    Apr 1, 2008
    Both are correct, they are just referencing different gamuts, NTSC vs aRGB.
  35. ashmedai
    12,403
    Feb 26, 2005
    I could swear this had been answered, but I'm not finding it. With all those nice delicious inputs, how are we for 1:1 scaling and black bars?
    (This is why we update the OP post with this stuff...)
  36. philjohn
    philjohn Limp Gawd
    261
    Apr 1, 2008
    Here's a quick test with 1:1 mode on:
    1920x1080 - ok
    1680x1050 - ok
    1600x1200 - ok
    1600x1024 - horizontal ok, vertical stretched
    1600x1000 - ok
    1600x900 - horizontal ok, vertical stretched
    1440x900 - both streched, AR ok
    1360x768 - both stretched, AR looks slightly stretched vertically
    1280x1024 - ok
    1280x960 - ok
    1280x800 - horizontal ok, vertical stretched
    1280x769 - horizontal ok, vertical streched
    1280x720 - ok
    1152x864 - both stretched, AR ok
    1024x768 - ok
    960x600 - both stretched, AR stretched vertically
    800x600 - ok
    So, to sum up, the main standard resolutions, plus the 2 HD resolutions, are handled perfectly in 1:1 mapping mode. Some of the more esoteric aren't. That's pretty acceptable as far as I'm concerned.
  37. ashmedai
    12,403
    Feb 26, 2005
    Same here - I'm not even planning to try it at anything other than Native and a few HD sources. Thanks!
    When you ran that, were the "black bars" filling the unused space reasonably dark and consistent - no odd effects of any sort there?
  38. philjohn
    philjohn Limp Gawd
    261
    Apr 1, 2008
    Nope, they were absolutely pitch black (doubly so since I've currently got my "night time" screen profile on which takes me down to a very low brightness).
  39. ashmedai
    12,403
    Feb 26, 2005
    Well then, it sounds like HP time!
    The Planar is nice for what it is, especially with the $750ish tag at Provantage...but the poorer dot pitch on 26" screens and the inconstancy between units doesn't sound like it's worth dealing with on something that's mainly seeing use as a computer monitor.
  40. emullet
    emullet n00b
    11
    Aug 15, 2008
    Tax almost kills the deal for me. $26 shipping, $46 tax puts this much closer to a Planar or a DS :(
