Hi everyone!
I havent posted on here in a while but Im kinda new to network storage and I wanted to upgrade my home file server which is just a old computer with 4x 3Tb drives in it running server 2012s software raid 5 on it.
I wanted to move to some more hardware raid based as well as more suited for server type work so I was able to pick up a HP G7 with 2x Xeon quad cores @ 2.4ghz and 36gb of memory 2gb x18 and a P410I raid controller card with 512mb and BBU for $200 bucks. I was then looking for a storage box to expand the drives capacity and found a HP MSA70 for $150 shipped.
I had to buy a PCIe card for the G7 for the SFF8088 ports out the back to connect to the MSA70. So I found a LSI 488765-B21 48910-001 HP SC08Ge 2Ports EXT PCIe SAS HBA on ebay for $20 bucks so I thought hey nice price and I ordered it.
For the hard drives I am currently using 14 76g 10K sas drives for testing but wil be buying WD Red 1tb drives once I can finish testing and can see that this setup will do what I want it to do for future expansion. I will be starting out with about 12-16 1tb drives and I will want to expand the raid array as I need more storage space.
I also installed a 16gb SD card into the motherboard of the G7 to install ESXI 5.5 onto. I know 16gb is over kill but I wanted faster R/W speeds and amazon had it on sale for 7 bucks
In a nut shell I want this to be able to boot from the SD card to ESXI (which it currently does) then create one large volume with the 1tb drives to store everything onto. I will be using some of the space for VMware labs as well as hold all of my files from my older file server.
I know have everything and put it all together but when the server boots up it boots the P410I card first so if I go into the config utility it only shows the 8 internal drives and not the ones that are in the MSA70 box. After that boots it loads the LSI card and displays those drives that are currently in it.
How do I get the LSI card to pass its information over to the P410I card? My research shows that the P410I card is meant to handle 108 drives. 4x MSA70s + the 8 internal drives. Ive looked at the boot order in the servers BIOS and Im not sure if Im missing something. Am I on the right track?
I apologize for the lengthy post but I wanted to give as much detail as possible and explain whats happening.
Thank you in advance!
