HP DreamColor LP2480zx - 24in LCD Monitor
psyside
Good monitor but the only review i saw for it say it dithers other then that
you can get 2 Nec 2490 for that price and even one of them is maybe better ;)
Biges
It implements the FRC (Frame Rate Control) in the full colour mode. Which not everyone uses. Otherwise it is an excellent monitor. Especially in Europe where NECs' 2490/2690 are relatively much more expensive compared to the USA market.
psyside
Well where i live The Nec 2490-SV is 1500 euros,2480zx is....2300!? about the full color mode didn't know
that so guess its also really good monitor maybe the only good as Nec 2490 to bad the price is insane.
Apparition
Hmm, I thought the dithering problem was solved with a firmware update.
It is worth noting that HP is running a good instant rebate on the monitor in the US. You can get the monitor for under $2000 (brand new) or under $1300 (refurbished). The offer is good until July 31st. However, you also have to include the price of HP Advanced Profiling Solution ($350). There is the hood which may set you back a couple of Benjamins or a bit less.
I may consider buying one. Does anyone have any experience buying refurbished monitors? Good/bad?
