HP 1GB DDR II - 667 MHz $7 AR
blairellis
Took mine to the post office and the lady said it only required a 41 cent stamp because I was under weight on mine. I put all the info they needed in one envelope too. 2 pages of photocopies of the barcodes, 2 pages from the rebate form, original invoice and it came out to the standard 41 cents. I would take it to the post office to have them weigh it if you are not sure.
annaconda
I was reading the rebate form, and we definately need to send copies or original UPC from each memory box.
So every one is confirming the serial#, i mean S/C# is serial number ?
dmkc1207
I bought 4 sticks...don't ask me why...but I bought 4 anyway...I have no idea why...I guess I just can't stand to pass up 4gb for under $12
r00k
in for 5. dammit i need to get away from this forum.
between hot deals and fs/ft, im dyin here! :p
annaconda
I should have bough 5 total. Oh well no computer too use them in :D every computer is filled up with RAM.
bpizzle1
my order came in today, but i had a question about what im supposed to make copies of for the rebate. the RAM itself had 2 stickers on each stick with barcodes that i scanned and printed. however, where are the upc codes located? are they on the cardboard boxes that the plastic cases came in? i had to take the RAM to my girlfriend's house because i dont have a scanner at my place that works atm, but i didnt bring the little individual cardboard boxes.
CentronMe
Ordered five sticks, this along with a new E2200 to replace the aging P4 640 will make for a nice VMWare server.
stevedave
Got the ram today. Put all four stix in a p5n-e sli.
4-4-4-12 works at both 667 and 800
5-5-5-18 works at both 667 and 800
Running prime95, while watching porn, while backing up a dvd, while converting movies onto my psp, while updating BF2 with patch 1.41 while posting this post and everything is running smooth as a pimp.
This is some good shit still can't believe I got it for 12 bucks.
Prentice
Got mine in. Wone be able to test until... who knows? I work 7/12's lol!
Very fast shipping and the packing it came in had to cost over the actual cost of what I ordered lol!
Gilthanis
[H]ard|DCer of the Year - 2014
Well...I broke down and bought 5....I'm debating on another 5 for another residence. This is waaay too good to pass up. I know I will get my money back out of them from custom builds, not to mention ram will go back up just as it has in the past as DDR-3 starts to come down.
mattc
rebate applies to 800 mhz too. bought 4 @ $8.36 each. They only show 40 in stock, but now it is 36.
edit- need to read posts first. already mentioned several times.
Luxor
lol, ebay is flooded with these, the soonest ending one is under $5+ship
Awesome deal, though.
F3rrum
I ordered 4 but don't even have a DDR2 compatible mobo to put it in.
Planning on a new gaming build this summer but was planning on going DDR3. Is DDR2<<DDR3? Can't imagine availability will be an issue in 1-2 years but will performance be?
/Read that DDR3 mobos are compatible with DDR2 so not even an issue now.
annaconda
Don;t expect DDR3 to be that cheap in the next year or so. I am sticking with DDR2 as long as i can. :D
Cobalt2112
Is there a MOBO that I can put this memory in that I can also put one of those fancy E8400 cpus??
ickywu
You can buy a couple mb's that run either ddr2 OR ddr3 but it's not like a mb using ddr3 is inherently backwards compatible with ddr2.
This is a really good deal on 667 memory. But we should probably remember this is memory designed for a 533 MHz system bus. Even if you can overclock it to 800, 1333 is still pretty far over the horizon for this ram.
kent
The Micron chips I got clock up to 1100MHz (4x1GB in a P5B Deluxe) at 5-5-5-15 2.1v
qwertyaas
I tried two that I got. Paired with my Ballistix, they wouldn't post over 800MHz at 5-6-5-18 at 2.0v. Didn't try any higher. I bought 2 more gig for my brother's system, so I might try those to see how those clock.
kent
Maybe I got really lucky.
In my opinion, they're "just as good as" the G.Skill "HZ" series RAM I use in the signature. They're D9GMH and these are D9HNL I believe.
ickywu
Extraordinary results. Especially with 4x1. AFAIK, only PQI used thewse as 800's. Go immediately, as in RIGHT NOW, to the track. Bet everything you have on whatever strikes you as a winner...
annaconda
I got micron chips too, but i did not tried to overclock them. I might give it a try.
Kett
In for 4.
The stock number is perpetually hanging around 2000. Every time it gets close to going under, they add a hundred or two more.
b1m2x3
i ordered 5 on saturday... should be here tomorrow.
can't wait. just a bit hesitant about going to xp64
Cobalt2112
goodcooper
just payed 115 for 5 gigs of ram and i STILL think its a good deal...
when i get 100 in rebates back it'll be like stealing memory from these people
kent
Now, I didn't intensively test them at 1100MHz, I was just screwing around one day.
It passed one round of memtest86+ (bootable CD) at 2.1V at 5-5-5-12 @ 1100MHz
horseflesh
I have 5 of these, also Micron chips. I just ordered the IP35-E from the Newegg deal... Now I just need to find a deal on a decent CPU with some room to OC.
dranom
the chips i got are D9 doesnt clock that well one pair got to 800 4-4-4-12@2.1v
but when i change to others you need loose timings to get to 800mhz
kent
I said 5-5-5-12 in the previous post and 5-5-5-15 in the top most post.
I meant the latter, 5-5-5-15
I ordered 3 sticks of this ram and i have tried 2 of them so far. I cannot get the 1gb sticks to show up as anything more then 512mb sticks. I am running on a crappy ECS P4M800PRO-M V2 mobo and these 1gb sticks are showing up the same as my old 512mb stick. i've tried flashing the BIOS and anything else i can think of. anyone having any similar issues?
