HOWTO: Make a bootable USB key... (for BIOS flash, firmware update, etc)
Discussion in 'Motherboards' started by NoxTek, Jun 13, 2007.
  1. ProjectNemesis
    ProjectNemesis n00b
    11
    Mar 29, 2008
    so is the command the same on all motherboards? the tutorial says:
    obviously the the first 2 parts are going to vary motherboard to motherboard but what about the /P /B /C parts? is that the standard for all motherboards?
    if you couldnt tell i have never updated the bios on a motherboard before.
    thanks for the guide.
  2. iPearl
    iPearl [H]ard|Gawd
    1,561
    Jun 13, 2007
  3. Sempron64
    Sempron64 Limp Gawd
    314
    Aug 24, 2005
  4. acameron_56
    acameron_56 Limp Gawd
    289
    Jan 26, 2008
    Thanks for the great tutorial, worked like a charm :)
  5. elec999
    elec999 Limp Gawd
    219
    Feb 11, 2004
  6. Crotan
    Crotan Gawd
    926
    Jan 2, 2007
    great know how but even this is becoming uneccesary, with things like Qflash where you just put the the BIOS file on a USB drive and point the motherboard to the file even before loading into the BIOS, not neccesary for it to be bootable
  7. kompulsive
    kompulsive Limp Gawd
    355
    Oct 11, 2008
    ...this will NEVER become unnecessary. That is blasphemy.
  8. stainremover
    stainremover 2[H]4U
    2,839
    Jul 19, 2008
    i think this is still the only way to flash things like video cards and raid controllers.
  9. Impulse
    Impulse [H]ardForum Junkie
    10,232
    Apr 5, 2001
    And a netbook's BIOS... Although I flashed mine using a bootable USB key made with unetbootin instead, was rather simple.
