My copy of the Thermal and Mechanical Design Guidelines for the E6000 family is over a year old. Go to intel.com - products - processors - whatever - whatever - technical docs and download a new copy to check me.
Appendix G, page 139 of my copy gives an overall max width (from edge of pushpin top across the HS to the opposite edge of a pushpin top as 4.7 inches and an overall height from the board to the top of the fan as 2.57 inches.
This document will also give you the "keep out" area around the socket etc. etc. so an updated copy should have everything you would care to know about the stock intel HS for your present CPU.
