TheCommander
- Apr 2, 2003
2500k with 8gb ram. Looking at a res of 1980x1200.
the game itself did not use that much ram. ram usage was only about 1.4 gb.Even though its was only a Beta........ my ran 45 to 60fps on 2aa everything on ultra(ran very smooth even with CB map and lots action going on)..but it was true it was a hog on my ram... 3.5 out of 4.0gigs of ram......went got 8gigs
Results:2011-10-08 21:49:40 - bf3
Frames: 5448 - Time: 116101ms - Avg: 46.925 - Min: 36 - Max: 80
did you really order an 8150?I bought a 5870 to play the beta. It did very well. Benchmarks of the beta show the 5870 as the best performance value by far. It's neck in neck with the 6950 and between the 580 and 570 gtx in multiple reviews of the beta.
It's definitely going to tide me over until ATI's 7 series.
............ but I expect to do well as long as you keep RAM usage below 1GB (read AA levels at 2x or 4x probably).
How do you keep Vram below 1GB, exactly?
I ran on Medium fine w/ my 5870, 8gb ram, q9550, 1920x1200; but, it was hard to get an average fps above 60 AVG!, which is ideal...........I'm not going to worry about tweeking it till I get the game.
you keep saying that and its NOT true. even at just 1280x960 I hit 1147mb on Ultra settings with 4x AA. 1 gb is NOT always going to be fine for 1080 in this game. and supposedly the beta was not even using the real ultra settings either.It doesnt use that much VRAM. I measured 850MB with Ultra settings 4xAA @ 1680x1050. 1GB will be fine fo 1080p as well. For higher resolutions dropping MSAA or textures to medium will help.
Ouch, I hope not. Better amend that signature!
and you are the ONLY person reporting just 850mb of usage on Ultra settings and 4x AA. I got more than that without AA and at just 1280. your claim that 1gb is enough for ultra settings and 4x AA at 1920x1080 is simply not true from what I have seen. I do understand that it will use more memory if you have it so its hard to get an actual determination of how much is really needed.1080p is not much more than 1680x1050. Others have tested it to run fine on 1gb cards. Its caching more memory than it needs which is why you are seeing that much. I can confirm the game uses only 850mb at max settings 1050p from gpuz readings.
About ultra not being ultra, we'll see about that.
your ram speed would have nothing to do on how much is being used. BF 3 beta used right at 1.4 gb every time I checked. for instance I was at 2.4gb of ram use in task manager being used before starting the game and never went over 3.8gb during the game.Could it be my 1333mhz ram that is slow? cause i use aida64 to monitoring the usage.
i did not say it was fake. I simply said you were the only person reporting such low ram usage for ultra settings and 4x AA. most of the 1gb owners completely maxed on their 1gb card with those settings. without AA, I was still at almost 1gb of vram usage in spots and turning on 4x MSAA shot that up to nearly 1150mb in spots and that was just at 1280x960.I am the only person you read about. So that makes it fake? How many person reports running out of VRAM in ultra settings 1680x1050 with a 1GB card? And you know for a fact 1GB is not enough for ultra because you have a 1GB card and a 1080p monitor to test with?
http://farm7.static.flickr.com/6053/6222166441_1da1c8ff4b.jpg
Yeah, you're right. It's up there but always behind the 570. I think I was thinking "between the 6950 and 6970".That doesn't sound right at all. Between the 570 and 580? I highly doubt it.
They're really, really bad processors. The fact it said 'to come' suggested they were considering buying one but hadn't done so yet - we're imploring them not to do it!
get over yourself as you do not decide who gets to comment on what around here. heck the guy did not even mind one bit that we made comments about it. and if anything it is YOU that needs to let it go and stop making a big deal out of it.Looks like he just hadn't updated his sig yet to me, but, did he ask for advice from either of you ?
Is there anyone left on the internet that could possibly be in the dark re: BD performance ?
If it had been any other product, would anything have been said ?
The worst thing about the BD release is you and everyone else like you, that even a week later still hasn't STFU about it, to the point of actually seeking out opportunities to shit all over it, whether it deserves it or not.
LET IT GO.
I most certainly can comment on what I see in a sig especially if its related to hardware. after all this is a hardware forum, genius. the only person being out of line in this thread is YOU.I'll take that as a yes then, to my original question, that open trolling of other members based on what they may or may not have in their sig is now the accepted norm, no matter how off-topic or unrelated it may be to the thread they post in.
You're running all AMD CPU systems, this tells me why you're so outraged by that comment.
Funny, 2.5 years ago, 1 GB was ahead of its time.
Now, 2 GB is necessary?
