heavenlykid
- Mar 18, 2005
Can any one tell me how to verify Snmp is working correctly on a windows box. And can I add I hate windows.
MIB walk?
-or- you could just make some changes and see if the right things happen.
whats mib walk? i need snmp to work on windows boxes so nagios monitor can chec them. problem is i dont know how to check snmp to make sure its working right
oops, read. comprehend. post.port 25 is SMTP....he's trying for SNMP.
go to www.ireasoning.com and download their MIB/SNMP browser. Run the application and and enter the IP address where applicable...then perform a "walk"...it should start spitting out values at you. Whatever you are using as an Agent should also come with a .mib file you can load into your MIB browser.
telnet xxx.xxx.xxx.xxx 25
run this on the host or the client ???
