How to turn on turbo mode
Discussion in 'Intel Processors' started by WilliamJones, May 15, 2019.
  1. WilliamJones
    WilliamJones n00b
    33
    Aug 19, 2018
    I am getting a new system with an i7 9700k CPU. It is advertised as 3.6 GHz and 4.9 GHz in turbo mode. How will I switch between the two speeds and how will I know which one is active?
  2. modi123
    modi123 [H]ardness Supreme
    5,144
    Sep 6, 2006
  3. E4g1e
    E4g1e [H]ardness Supreme
    7,053
    May 21, 2002
    Turbo should be enabled by default.
    As for the maximum turbo mode speed, that depends on how many cores are in use. That varies from 4.9 GHz when only a single core is in use, 4.8 GHz when two cores are being used, 4.7 GHz with three or four cores used, and finally 4.6 GHz when more than four cores are in use.
  4. CAD4466HK
    CAD4466HK [H]ard|Gawd
    1,219
    Jul 24, 2008
  5. Dan_D
    Dan_D [H]ardOCP Motherboard Editor
    53,244
    Feb 9, 2002
    You don't need to do anything.
    drescherjm likes this.
  6. EnderW
    EnderW [H]ardForum Junkie
    10,786
    Sep 25, 2003
    IMO the single core turbo speed is almost meaningless cause usually at least 2 cores are loaded
  7. E4g1e
    7,053
    May 21, 2002
    And in the history of turbo'd Intel CPUs, there have been a few that stayed at stock non-turbo speed when all cores are loaded. And there may have been a couple that stayed at stock non-turbo speed when more than two cores are loaded.
  8. auntjemima
    auntjemima [H]ardness Supreme
    4,348
    Mar 1, 2014
    blkt and CAD4466HK like this.
  9. EnderW
    10,786
    Sep 25, 2003
    Not sure I follow what you’re saying. For most current gen CPUs you can find the turbo tables on chip wiki or Wikipedia.
