I've never really had a need to do this but i'd like to hook up some fans in the shop for exhaust when soldering. Plus now that i thought about it i was just kinda curious, so anyone know howto do this? Or should i just go dig up an old AT unit?
Originally posted by bobcrotch
"Find the ATX mobo plug, find the green wire, (should be only one, if there are multiple green wires... then your PSU sucks, i wouldn't go any further), and take a piece of a wire so that you can connect something, than find a ground wire (should be 6, these should be black), and connect the green wire to the black wire, basically by shoving the third piece of a wire you have into both of those two plugs"
Stolen from the FAQ so you guys know too.
Hey you were close majordomo, not just trying to kill my fat ass =b
Originally posted by Syphon Filter
Do u not have to have a load attached to get the PSU to power up as well? ie if nothing is connected then it will not power up?
