CaffeineMan
- Nov 29, 2013
**MY MISTAKE** I misidentified the LED connection as the power button connection.
Original question:
I received some laptop mobos without shells (Lenovo 13 2nd gens) that I would like to upcycle to use as my HTPCs. I currently use slower laptops (actually parts of laptops) but would like to upgrade what I already have.
I have identified where the power button should attach and tried shorting out the pins (like I would do for a PC mobo), but this did not work and I am unable to power on the board.
My troubleshooting steps are as follows:
Any ideas on how to boot a laptop without a power button?
Original question:
- Found a "working" Lenovo 13 2nd gen. Disconnected the power button. Pressed the power button. The laptop did not power on. (this proved I have the right cable). Also, the cable only has 2 leads.
- I shorted out the 2 pins that the cable indicated I should short, but the "working" laptop did not boot up.
- I reconnected the power cable and pushed the power button. The laptop powered on as expected.
- I tried running a continuity test on the button at the cable side but did not see any continuity (my tester does not have fine points so I am not sure this test is bad data caused by the poor execution of the test).
