So im almost done building my 8700k and I just got a set of LPX 3600 at 18ns from Corsair at 16gb for 209 dollars.
Will faster CAS make a difference with kaby/coffee or will raw throughput be the biggest difference?
Is it possible to tighten timing, leave clockspeed at 3600mhz and hust add voltage? Or would there be any benefot tondropping to the ram to say 3466 and run cas 15 or 16 at higher volts....?
I am not a good ram OCr. Thanks for advice.
