Ice Czar
Inscrutable
- Jul 8, 2001
in three easy steps
1. copy this text into a notepad and save it as noaccess.rat
and save it in WINNT\system32 (W2K) WINDOWS\system32 (XP)
2. Open IE > Tools > Internet Options > Content > Enable > General tab > Rating Systems > delete all > add > noaccess.rat > OK > Approved Sites Tab > add
http://technet.microsoft.com/
http://update.microsoft.com
http://support.microsoft.com/
http://www.microsoft.com/windows2000
http://www.microsoft.com/windowsxp/
clicking "always" after each > General Tab > User Options > Check Supervisor can type password to allow users to view restricted content > uncheck Users can see sites that have no rating > set password
3. install Firefox with the noscript extention or Opera
IE is now secured
might make sense to restrict that folder's NTFS permissions as well
Program Files\Internet Explorer > Properties > Sharing Tab > check do not share > Security Tab > remove all users except yourself (Administrators)
Code:
((PICS-version 1.0)
(rating-system "http://www.microsoft.com")
(rating-service "http://www.microsoft.com")
(name "Noaccess")
(description "This file will block all sites.")
(category
(transmit-as "m")
(name "Yes")
(label
(name "Level 0: No Setting")
(description "No Setting")
(value 0) )
(label
(name "Level 1: No Setting")
(value 1) ) ))
IE is now secured
