How to run .exe hidden (not minimized not on front)?
oiiwj
Hello,
i think (not sure) in batch scripts one can use:
start "" /MIN "C:\Windows\System32\taskmgr.exe"
(maybe use /B instead of /MIN)
but when i use Win.+R it do not seem to accept "start". The process i want to run opens a windows shell/terminal and when i close terminal, the app terminates.
Also when i create a shortcut to that .exe and in shortcut properties append "/MIN", it has no effect, still the terminal window is visible. I solved it by downloading Quiet.exe from http://www.joeware.net/freetools/tools/quiet/index.htm
into C:\Windows\System32
and then modifying the shortcut path to:
C:\Windows\System32\Quiet.exe "C:\my.exe"
And it works, window do not bother me anywhere and process is running.
It doesn't work in the run dialog (Win + R) because "start" is a command built into the CMD shell. The run dialog executes or opens files directly according to their file associations. Since "start" isn't a command file, the run dialog just doesn't know what to do with it.
Adding the /MIN switch to the .exe shortcut didn't work because you're passing the switch directly to the .exe file for it to parse when it runs. If it's the programmers of the .exe file didn't add that as a valid switch, then it'll either ignore it or give you an error.
"start" was programmed to accept the /MIN switch and knows what to do with it. If you'll notice in your example, it's located before the .exe file "start" is being asked to run.
Hope that helps.
Reactions: oiiwj
Create a scheduled task (using Task Scheduler in Control Panel -> Admin Tools) and set the task to run as SYSTEM. You'll need to run the task from Task Scheduler, but it should run in the background out of sight.
