How to run a Dell 2209WA at 75Hz
Discussion in 'Displays' started by evilsofa, Apr 25, 2009.
  1. evilsofa
    evilsofa [H]ardForum Junkie
    10,078
    Jan 1, 2007
    I'm seeing in the 2209WA megathread that it's possible to run it at 75Hz, but it takes a little technical work to do. I'd like to start this separate thread to put together clear instructions on how to do so for both nVidia and ATi users, and also to find out if all 2209WA monitors can do it, or only some. I don't own these monitors myself, but my brother-in-law has two, so I'll quote what's been said on this topic so far that I can find:
  2. giskard
    giskard n00b
    3
    May 14, 2009
    Hi All. I've had success using the settings provided by ToastyX on a nVidia 8800GT, but have since changed to the ATI 4770 and im having trouble getting back to 75hz. I've read that powerstrip is the ticket to 75hz, but im unsure of the settings to get it over the line. Could someone post a screen grab of the correct powerstrip settings?
    Cheers,
    G
  3. Tosan
    Tosan Limp Gawd
    147
    May 3, 2007
    Creating a new custom resolution in the Nvidia control panel with ToastyX's settings worked fine for me with an 8800 GTS under Windows XP. It doesn't seem to support fractional refresh rates so I'm at 76Hz instead of 76.647, but I had no problems getting that to work. PowerStrip, on the other hand, did not work for me at all.
    I'm also using RefreshLock to lock the monitor at 76Hz in games.
  4. giskard
    giskard n00b
    3
    May 14, 2009
  5. SJetski71
    SJetski71 [H]ardForum Junkie
    14,329
    Sep 6, 2002
    You may want to read this thread closely, and give his software a whirl, just to be sure you're not wasting your time.
  6. rhiridflaidd
    rhiridflaidd [H]Lite
    72
    Aug 30, 2006
    http://www.hardforum.com/showthread.php?p=1034028590
    Shows that it does not skip frames.
    http://www.ocforums.com/showthread.php?t=603714
    There is a lot of info in this thread about different nvidia drivers and it's impact. Basically read nd4spdbh2's posts- some posts in this link are misleading.
    edit.
    Just tried it - it works - easy. A few pics seem to confirm that no frames are being dropped.
    p.p.s.
    But I can't seem to get refreshlock to work. When I run it it frops the refresh to 60. It only accepts 60 as "safe."
  7. ilear
    ilear n00b
    1
    Jun 19, 2009
    hi there,
    i tried to set it as described, but when i select 75Hz and open timings, i see ~81 Hz refresh rate, is that safe? Or i should set in upper selectbox so much Hz to have 75Hz on bottom?
  8. ZippityDoDa
    ZippityDoDa n00b
    5
    Sep 27, 2009
    I am running Windows XP with an Nvidia GTX260, and used to be able to get the monitor to run in 75hz, through the instructions. Well today I updated my drivers as it had been a little while since I had done so. And now with the newest drivers (195.62), I am not able to get this monitor to 75hz.
    The layout of the control panel has changed slightly since I last updated (it had probably been a solid 2 or 3 months since my update). But I found the "custom resolution" menu, added the settings by ToastyX, which have worked up until this point. Now I click test, screen goes black for a second it comes back, the option "click yes to keep settings" pops up. During this time, according to my monitor, the 75hz is in effect. So I click yes to keep settings, the screen goes black again for a second. In the graphical settings I can still see it is 60hz, and on the menu of the monitor I see "1680 x 1050 @ 60hz" as well.
    http://img39.imageshack.us/img39/175/nvidiax.jpg
    I am sure it is a problem with the thing sitting between the chair and the keyboard, but I have tried multiple times all resulting in failure.
  9. precariousgray
    precariousgray Limp Gawd
    166
    May 4, 2005
    Thanks for consolidating this information. My 2209WA should arrive soon, and I'm definitely interested in seeing if I can get 75hz working properly with my 5770!
  10. Disconnect
    Disconnect [H]Lite
    74
    Dec 23, 2002
  11. Jerec
    Jerec [H]Lite
    109
    Oct 22, 2009
    What's the reason to bump it up to 75Hz?
  12. precariousgray
    166
    May 4, 2005
    Disconnect, what settings did you use in Phoenix? I'm not sure which ones in the first post correspond to what's showing in the "Detailed Timings" tab, if that's even the correct place.
    Great, now I feel like a moron. ;-(
  13. btgorman
    btgorman Limp Gawd
    229
    Jun 30, 2009
    Can the 2209WA run at 3x75hz if you use 3 in eyefinity?
  14. Xuerian
    Xuerian n00b
    58
    Oct 6, 2008
  15. Groats
    Groats n00b
    38
    Dec 26, 2008
    Is there any risk of damaging the monitor by forcing up the Hz?
  16. TeraMeow
    TeraMeow n00b
    17
    Nov 12, 2009
    Yes, but you can check the 2209 thread and look at what others are doing to reduce the risk.
  17. dunnno
    dunnno [H]Lite
    94
    Sep 16, 2003
    I doubt it since it's part of the official specs.
  18. doz
    doz [H]ardness Supreme
    4,817
    Jun 16, 2009
  19. precariousgray
    166
    May 4, 2005
    That driver's finally got me running at 75hz, yay! Apparently I'm too much of a lazy, moronic schlub to figure out which settings to change in Phoenix on my own. Thanks for the link!
  20. sideeffect
    sideeffect n00b
    10
    Sep 25, 2007
  21. aggressor
    aggressor Limp Gawd
    354
    Jun 25, 2003
    This worked for me after a reboot. No need for additional programs = hooray :D
    I DO have a question, though...if this is part of the official specs of the monitor, why does it require hacks to activate 75\76hz? Certain other monitors let you, so why not this one?
  22. Matija
    Matija Limp Gawd
    244
    Sep 5, 2008
    It's not a part of the official specs - it's a hack. The monitor _may_ be able to do 75 Hz, but it's not guaranteed. My monitor starts displaying corruption in the form of horizontal lines, and it also starts making a noise. I'm quite convinced that running *my* monitor on 75 Hz for a short while would destroy it. It works for some monitors, but not for others.
  23. aggressor
    aggressor Limp Gawd
    354
    Jun 25, 2003
  24. precariousgray
    166
    May 4, 2005
    Still no issues running at 76hz, but I can't really be sure if there's much of a difference from 60. Still lots of tearing in games, but at least I can press the menu button for the OSD and see 1680x1050@76Hz at the bottom!
  25. Leopardi
    Leopardi Limp Gawd
    217
    Feb 15, 2010
    So how do I run it at 75Hz? I have an ati card. I tried refreshlock, refresfroce and dxdiag value thingy. It just reports 60hz. Then I went to the timing settings in powerstrip and chose 75hz for vertical and there were artifacts all over the screen.
  26. evilsofa
    10,078
    Jan 1, 2007
    See sideeffect's post earlier in this thread (post #20).
  27. Leopardi
    Leopardi Limp Gawd
    217
    Feb 15, 2010
    I want 75Hz, it feels better in games.
  28. rhiridflaidd
    72
    Aug 30, 2006
    If the spec says 75 why are you guys running it at 76??
  29. dizolit
    dizolit Limp Gawd
    222
    Feb 13, 2010
    The modded EDID from wsg most people are using bumps it up to 76hz. Don't know why 76 instead of 75, but 75hz isn't an option with the mentioned EDID.
  30. wagsrules
    wagsrules [H]ard|Gawd
    1,048
    Aug 18, 2006
    75 and 76 hz are both options for me. I run an ati 5770.
  31. rhiridflaidd
    72
    Aug 30, 2006
  32. SYN ACK
    SYN ACK [H]ard|Gawd
    1,243
    Jul 11, 2004
  33. rhiridflaidd
    72
    Aug 30, 2006
    Right. I'm a novice here, but on messing with this inf...
    http://www.overclockers.com/forums/showpost.php?p=6280080&postcount=159
    I can see that the horizontal refresh is indeed set at 76, but the vertical refresh is still at default, whilst the spec for this monitor
    http://support.euro.dell.com/support/edocs/monitors/2209WA/en/ug/about.htm#Specifications
    at 75hz is 86 khz.....
    So this monitor, even with this inf is still running below system spec.
    The bloke in the OC forum clearly knows what he's doing.....
    I can create a dat file that reads
    1680 x 1050p at 75Hz - VESA STD
    But the detail timings is something different again.
    So.....who is expert enough to get this pixel clock up to 187?
    Edit- Some theory
    http://www.mcamafia.de/mcapage0/timecalc.htm
    "1680x1050" 146.250 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync Default
    "1680x1050" 153.290 1680 1712 1744 1842 1050 1053 1059 1089 -hsync +vsync - killer's dat.
    K
  34. einz
    einz Limp Gawd
    464
    Jul 27, 2004
    Can someone explain to me the appeal of 75Hz? I understand why higher resolution is better back in the CRT days, but what's so good about 75 vs 60? Is it simply a matter of higher perceived FPS? Doesn't your eye lose the ability to see >30-40fps?
  35. rhiridflaidd
    72
    Aug 30, 2006
    The neuropsychologyists did not use fast paced FPS's in their testing methodology - perhaps they should. Gamers know that the scientists are wrong on this one.
    Right on digging, the answer to why killer wrote his setings as he did is that the Dell settings with a 187mhz pixel clock can't work because a DVI connection has a 165mhz cap.
    This monitor seems happy at 76, so why not go for the 1mhz extra.
    So there we go.
    The 76 dat works for me, and I can use it in BFBC2 - that's all I need!
    The scientists can set up a clan game of counterstrike, one team with vsync set at 75, the other with vsync set at 40 so this can be settled once and for all.
  36. evilsofa
    10,078
    Jan 1, 2007
    No.
    http://www.100fps.com/how_many_frames_can_humans_see.htm
  37. Leopardi
    Leopardi Limp Gawd
    217
    Feb 15, 2010
    Still no 75Hz driver available?
  38. Koslov
    Koslov [H]ard|Gawd
    1,889
    Aug 31, 2003
    I'm having problems with the latest NVIDIA drivers on a 8800GT
    Any updated info for Nvidia users? Never had a problem with my ATI card
  39. TechHead
    TechHead 2[H]4U
    3,869
    Oct 12, 2001
    ^Mine works at 75hz, using an 8800GT SLI setup + 257.46 drivers IIRC.
    Will check when I get home from work today.
  40. Neochrome
    Neochrome n00b
    4
    Feb 22, 2012
    Sorry for resurrecting this old thread, but I have jut tried to "overclock" my DELL 2209WA to 76Hz refresh rate. I did it with the help of manual settings, in nVidia Control Panel, with just a little change: Total vertical pixels at 1088 (compared to 1087 from a guide) and Polarity +/- (horizontal / vertical). And polarity is my question, because it seems to not change anything visible on the screen, and I can do 76Hz with +/- or -/+. What is the purpose of the Polarity? How is it affecting your panel/screen/its quality? Thank you...
