How to properly clean out AIO that has growth?
Discussion in 'Water Cooling' started by SlayVus, Apr 27, 2019.
  1. SlayVus
    SlayVus Limp Gawd
    193
    Jan 13, 2011
    So I have an Enermax Liqtech TR4 280MM AIO and it has the defect of low biocide and anti-corrosive in the glycol mix. I've already emptied the AIO and am waiting on the Primochill Sysprep and Primochill Liquid Utopia(Biocide and anticorrosive) bottles to arrive, which each bottle says it treats one gallon of water.
    Whats going to be the best way to make sure I get the radiator cleaned out as best as possible? I'm going to remove as much as I can from the cold plate since I already have it removed from the block and try and clean out the block as well.
  2. Ocellaris
    Ocellaris Ginger @le, an alcoholic's best friend.
    18,795
    Jan 1, 2008
    Fill the rad with vinegar and let it soak. Drain it and see what comes out. Do another vinegar flush and drain again... Repeat it until it comes out clean. Then flush it multiple times with distilled water.
    SticKx911 and pendragon1 like this.
  3. pendragon1
    pendragon1 [H]ardForum Junkie
    12,865
    Oct 7, 2000
    yup^^ and use a toothbrush and paste to clean the cold plate. I just posted the GN video of them doing theirs in the TR4 thread.
  4. Nicepants42
    Nicepants42 Gawd
    752
    Aug 30, 2004
    Toothpaste? I've always just used a vinegar bath + toothbrush for block bases. And when rinsing/flushing, I use boiling distilled water.
  5. pendragon1
    12,865
    Oct 7, 2000
    yup it will help scrub off any crap without damaging the copper. that works too.
  6. Nenu
    Nenu [H]ardened
    18,723
    Apr 28, 2007
    Best way to clean fine finned blocks is with a jet steam cleaner.
    I bought one for £15 from Lidl and it is perfect.
    Brought my Apogee XT Extreme back to like new.
  7. magoo
    magoo [H]ardForum Junkie
    14,348
    Oct 21, 2004
    Take off the rubber gasket and let the block soak in a diluted vinegar solution overnight.
    Then using a toothbrush scrub the block with clean dilute vinegar.
    Rinse it with clean distilled water.
    Do the same with the radiator, run hot water-vinegar through and then rinse with distilled water.
  8. hititnquitit
    hititnquitit Limp Gawd
    378
    Apr 16, 2018
    for rads and copper parts ive been using clr for years. it takes less than a 1/2hr and cleans better than anything else youll find. fill the rad full of clr. let it sit for 5 mins shake the hell out of it and drain it. flush it out 2 or 3 times with tap water until the water comes out clean. rinse one more time with distilled water and your set to reinstall it. for copper/aluminum parts its essentially the same process just use a toothbrush to clean the fins after letting it sit.
