How to passively cool a Quadro P620?
Discussion in 'Overclocking & Cooling' started by PinPickles, Jun 13, 2019.
  1. PinPickles
    PinPickles n00b
    15
    Jun 13, 2019
    Hi, I'm wanting to put together a silent, efficient "hobbybox" (a workstation for d*cking around) build with a Quadro P620.
    Not sure how I can make the Quadro fanless though. I'd just live with one fan in the system, but I hate dealing with dust and cleaning it out, so that is my main reason, besides noise.
    I've found the Arctic Accelero S3, of course, and this cooler Thermaltake used to make (https://www.amazon.co.uk/Thermaltake-Passive-Cooler-Fanless-CL-G0115/dp/B002DK9XLW) .
    The Accelero S3 looks like it's probably overkill for what I need though, and it isn't indicated to be used with the Quadro P620. I also can't find how much the Thermaltake can dissipate. The Quadro P620's TDP is 40W.
    What would be the best way to do it?
  2. Alienslare
    Alienslare Limp Gawd
    160
    Jan 23, 2016
    The TDP for this card should not be a problem but the heatsink in the amazon link isnt a relevant one for your card until you physically check it to fit.
    I tried to find similar with reference to those entry level asus geforce cards but im not sure if they would fit, even if you buy those in dead condition for the sake of having their heatsinks.
    Care to do a bit of modding ? :sneaky:
