How to overlock Xeon 2658V3 on this motherboard?
Nikoshka
This is X99 LGA2011-V3 motherboard without brand's name ... I'm found this in BIOS but not understand how to use this? Main target this is up all cores from 2.0Ghz to 2.2Ghz and more ... CPU this is ES version of 2658V3 and many people in comment on AliExpress posting only this ES CPU with 2.3Ghz and other without they other hardware ...
May be this is not full motherboard futures?
May be i'm ca use desctop software?
newls1
i had this cpu and used a program called "throttle stop" and had all my cores @ 2.5/2.6ghz (cant recall which, as its been a min) I actually used 2 of these cpus on a dual skt2011 board and its was a fun PC to build. First ever dual skt build i did and learned ALOT about how to find exact matching ES CPU's and how important that was.... nvr again will i do that!
Nikoshka
Thanks, i'm download this software =) I'm don't know how use it and will search manual ... This is one soft for my CPU+Motherboat that get correct information about system and not disabled all settings for me ...
p.s. I'm use only one CPU
tno
A very generous local decided to donate an R620 so I could run a Minecraft server for some local kids and I have been quietly eyeing that second socket just for giggles. Your post might make me second guess dealing with that.
J
newls1
the techpowerup website has a forum sub-section post going on just for this software and the maker of the software regularly responds to all people needing help
