How to open a port in ISA 2006
ashman
Does anyone know, or able to provide a link, on how to open a port in ISA 2006, step by step?
So for example, if you wanted to open port 22559 incoming from either anyone or a static IP, NAT'd to an internal IP, what would be the steps?
The setup is SBS 2003 Premium edition, two NIC's, DSL on the external NIC with a static IP.
Thanks
AM
I'm not going to type out a step by step write up, but you need to
1. Define the protocol - 22559 TCP
2. Create a server publishing rule (non-web protocols) and do your mapping from external IP to internal IP there.
www.isaserver.org is a good resource too.
