How to limit wifi speeds?
Discussion in 'Networking & Security' started by ChRoNo16, Feb 13, 2019.
  1. ChRoNo16
    ChRoNo16 [H]ard|Gawd
    1,406
    Feb 3, 2011
    I have a Ubiquiti Unifi AP-AC lite, the cheap 50$ edgerouter, and a 3com 4500g switch.
    I want to limit how much internet bandwith the wifi can use at a time (Im lagging out when gaming)
    How do I do this?
  2. Rifter0876
    Rifter0876 [H]Lite
    102
    Nov 1, 2017
  3. Brian_B
    Brian_B 2[H]4U
    2,563
    Mar 23, 2012
    Limit by client, by application, or just anything on WiFi in general? I do hope you realize the issue ~probably~ isn't your local WiFi, it's probably your ISP.
    Also - standard comment "If your gaming on WiFi, switch to copper"
  4. Farva
    Farva [H]ard as it Gets
    35,139
    Feb 3, 2004
    How many people are on your wifi and using it?
  5. elavanis
    elavanis n00b
    37
    Feb 1, 2008
    Under QOS you have an option for smart queue. I would try this 1st since it will be more dynamic in that it will allow wifi to download/upload at full speed while your not gaming. However if your internet speed is above ~100mb the edge router x will start to bottle neck you with smart qos on.
    If that doesn't work though you could got more draconic and set the limit for wifi to be a fraction of your internet speed but you will always be limited to that speed. For that to work you would either have to create a "wifi" group or move them to a vlan so you could affect the group with 1 qos rule. That gets a bit more complicated which is why I personally went with the smart queue on my ERL.
    ZeqOBpf6 and FNtastic like this.
  6. TordanGow
    TordanGow Gawd
    912
    May 25, 2015
    You can limit by client in the UniFi software. I use this for guest devices. If I don't like you, you go to slow, haha.
    FNtastic likes this.
  7. FNtastic
    FNtastic [H]ard|Gawd
    1,338
    Jul 6, 2013
    This. Setup a separate SSID. Setup a User Group with bandwidth limitation. Apply said User Group to said SSID. Problem solved.
