How-to Guide for Virus/Trojan/Malware Removal
Discussion in 'Networking & Security' started by Captain Colonoscopy, Jun 12, 2009.
  1. Captain Colonoscopy
    Captain Colonoscopy 2[H]4U
    3,861
    Feb 19, 2004
    Good stuff there. Thanks for the link.
  2. quicktech12
    quicktech12 n00b
    12
    Dec 18, 2009
    Thanks for this thread about malware removal. I downloaded the sysinternals pdf and checked out some of the other great resource links. I have seen these fake AV programs more frequently since late last year. Sometimes they do damage to Windows that requires a clean install to fix. Other times they can be removed with a quick scan using mbam. One tip that I learned is to use the cmd prompt to install and run your av app. These new fake av's are disabling the .exe in windows, and even safe mode at times. However if you have mbam on a usb drive, then you can open cmd and browse to the .exe file to install and run it in normal mode. Also, I have seen if you delete the infected file it can disable certain critical windows functions. Hope that helps someone dealing with these Fake AV's.
  3. Sp33dFr33k
    Sp33dFr33k 2[H]4U
    2,481
    Apr 20, 2002
    Got a system yesterday with a bootkit/rootkit infection. Never had to deal with one of these so it should be interesting.
  4. yomabingo_maria
    yomabingo_maria n00b
    1
    Feb 8, 2012
    thank you so much,
    this solve my problem, cause everytime i open the "my documents" folder
    the folder hangs up and when i check in task manager,saw there that
    the "my doc" folder is not responding
    i always get that error, i'll consider i'm lucky when i can access that folder
    without any problem.
    and i don't want to take the option of reformatting my laptop, too lazy about it XD
    good thing there is a very nice tutorial here.
    thanks again!!!
  5. daglesj
    daglesj [H]ardness Supreme
    5,027
    May 7, 2005
    Been using Malwarebytes as part of my virus removal routine on infected drives for a couple of years now.
    Essentially infected drive is removed from PC slotted into a SATA caddy and scanned on my scanner PC with at least 4 products.
    Am I the only one to notice that Malwarebytes rarely if ever finds anything now? I can have MSSE etc. pinging up red left right and center but Malwarebytes just finds zip. Not even bad cookies. This isn't a bad install as I rebuild the scanner often and always install the latest version. This has been happening over the past 3-4 months or so.
    Just doesn't appear to be effective at all anymore. May soon get dropped from my regime.
  6. CubanBlood
    CubanBlood [H]Lite
    101
    Jun 4, 2010
    Very helpful information. Thanks
  7. R3ckless
    R3ckless [H]Lite
    75
    Jul 19, 2010
    Another good removal app i just found is comodo cleaning essentials. it works alot like nortons power eraser.
  8. yujie
    yujie [H]ard|Gawd
    1,105
    Apr 15, 2002
  9. nghiasimon007
    nghiasimon007 n00b
    6
    Nov 9, 2012
    information is very helpful for everyone.
  10. janey6152
    janey6152 n00b
    35
    Dec 1, 2012
  11. wtburnette
    wtburnette 2[H]4U
    3,581
    Jun 24, 2004
    After getting a job on the security side of the industry, I would also urge people to harden their systems. Basic things like not using an account with admin privileges, changing default system ID's and using complex passwords, disabling unused services, uninstalling unused apps, running a firewall, enabling UAC, keeping OS and third party apps up to date, as well as running an up to date AV software package. I've been slowly hardening my systems and I have to say I'm shocked over how I used to run my system.
  12. BobSutan
    BobSutan [H]ardForum Junkie
    9,189
    Apr 5, 2000
    How current are the tools listed in the OP? I'm about to rebuild my system and need to do a deep scan of the date I'm going to keep and don't want anything I may have missed to reinfect my fresh build.
  13. Captain Colonoscopy
    3,861
    Feb 19, 2004
    Most of the tools are still current, links might have expired though. I still use MBAM, SAS and ComboFix to clean up infected PCs. Security Essentials for free AV software. One of these days, if I ever find some spare time, I might just revise/update that post...
  14. wtburnette
    wtburnette 2[H]4U
    3,581
    Jun 24, 2004
  15. Life.exe
    Life.exe n00b
    13
    Nov 13, 2012
    I use HijackThis frequently for browser hijacks and it is an awesome tool. You are right though, it can be more of a problem if you don't take the time and learn how to properly use it.:(
  16. StuartDavidson
    StuartDavidson n00b
    2
    Nov 16, 2013
    Wow, great advice in this thread. I wrote an article that is WordPress orientated that might help people harden their blog security and avoid any malicious hacking attempts.
    You can read my article here is you think it will help you:
    http://stuartjdavidson.com/wordpress-security/
    Anything I can help with WP wise then let me know.
  17. daglesj
    5,027
    May 7, 2005
    Dont forget EMET 4.1!
  18. automaton
    automaton Limp Gawd
    165
    Feb 5, 2003
  19. automaton
    automaton Limp Gawd
    165
    Feb 5, 2003
  20. Simmonz
    Simmonz 2[H]4U
    2,506
    May 14, 2008
    Pretty decent list. My usual routine at work is:
    1. Run Kaspersky Rescue CD
    2. Run Avira Rescue CD
    3. Run Comodo Rescue CD
    4. Go into safe mode
    5. Run Rkill
    6. Run CCleaner
    7. Run Malwarebytes
    8. Run JRT
    9. Run ComboFix
    10. Run ADW
    11. Go into Normal Mode
    12. Run whatever the customer has on full scan (or put something on there if they have nothing or crap)
  21. daglesj
    5,027
    May 7, 2005
    Cryptoprevent https://www.foolishit.com/
    Essential to stop the encryption viruses. Even the free version can help stop or slow it down.
    I now recommend it a lot. Not expensive either. Seen a few small firms lose all their data and they weren't running it.
  22. x509
    x509 [H]ard|Gawd
    1,687
    Sep 20, 2009
    And there is a free version also. Thanks for this tip.
  23. jefferysummers
    jefferysummers n00b
    35
    Apr 29, 2015
    Malwarebytes Anti-Exploit is a best solution for malware problem.
  24. daglesj
    5,027
    May 7, 2005
    It's just a different version of EMET.
    About time MS put EMET into Windows 10 as standard.
  25. oneforspeed
    oneforspeed [H]Lite
    102
    Jan 6, 2012
    Guys thanks for all this info and the start of this thread. I was looking all over for help and found this here while cruising around. I generally just buy on the for sale thread but this community has a ton to offer.
    Killer!
  26. Zahid Iqbal
    Zahid Iqbal [H]Lite
    64
    Oct 31, 2015
    very interesting list.
  27. Zahid Iqbal
    Zahid Iqbal [H]Lite
    64
    Oct 31, 2015
    Best ever guides, I see on internet. Personally i use KasperSky
  28. SKiZZ
    SKiZZ Gawd
    514
    Mar 9, 2000
  29. leSLIe
    leSLIe Fisting is Too Mainstream for Me
    13,987
    Oct 18, 2004
    Does this how-to guide need an update?
  30. jshaw42
    jshaw42 Gawd
    526
    Apr 18, 2016
    I am currently running Malwarebytes on all my PCs. Is it necessary to add Spybot Search and Destroy?
  31. scgt1
    scgt1 [H]ardness Supreme
    5,095
    Jun 4, 2007
    Any of these work for removing ransomware? My dad's work has been effected with a time limit and a 2 BTC demand to unlock the files. This is their server that is effected so EVERYTHING is locked down. The owner is looking at paying the BTC.
  32. JHefile
    JHefile Necrophilia Makes Me [H]ard
    1,180
    Jun 22, 2003
    Bleeping Computers is a well respected site for the fight for our clean computers. Click on the anti- ransomeware tab and see what you can do. https://www.bleepingcomputer.com/download/windows/
