How to get Wattman to auto-apply?
Discussion in 'AMD Flavor' started by LigTasm, Jun 5, 2018.
  1. LigTasm
    LigTasm [H]ardness Supreme
    5,282
    Jul 29, 2011
    I was wondering if any of you fellow AMD users figured out how to get Wattman to auto-apply settings at startup?
    If left completely alone, my V56 seems to be set up with a different HBM speed every boot (sometimes 700, sometimes 800, I've seen 500 a few times as well).
    I have a profile with the card undervolted on the core and the HBM and power limit pumped up a bit, but I rarely remember to open up the damned app and apply it. Is there an option I'm missing that does this or does everyone go through this annoyance? I really like the wattman program otherwise.
  2. Mega6
    Mega6 Gawd
    767
    Aug 13, 2017
    Radeon Settings -> Global Settings -> Global WattMan Tab -> Load/Save Profile Upper Right
    make sure you can write to C:\Users\%USERNAME%\AppData\Local\AMD\CN dir and files.
    edit - and dont set the power limit.
  3. LigTasm
    5,282
    Jul 29, 2011
    Does it only load on startup if you don't set the power limit? My card is under water and I see an extra 60-80mhz with the power limit +50%.
  4. d8lock
    d8lock Limp Gawd
    447
    Feb 12, 2012
    I have the same question. Having to manually apply a profile for each card at startup is pretty damn inconvenient.
  5. Mega6
    Mega6 Gawd
    767
    Aug 13, 2017
    power limit was affecting my testing. play with it last.
  6. Mega6
    Mega6 Gawd
    767
    Aug 13, 2017
    see above.
