In XP you can easily disable/enable your internet connection by using the network icon. In Vista I have the network icon and an icon for my router. The network icon doesn't show disable when I right click it but the router icon does. Why would a router have a disable option? Clicking disable on the router icon does nothing anyway. Microsoft neglected to put disable/enable on the network icon they put in the system tray. I guess they want us to be connected 24/7 but I don't and I don't want to have to go to device manager to disable the NIC
every time either. This is so easy to do in XP so why the hell did they change it in Vista?
