How to differentiate between MSI GS63VR vs the max q version?
Discussion in 'Mobile Computing' started by lachdanan, Oct 10, 2017.
  1. lachdanan
    lachdanan Limp Gawd
    231
    Nov 3, 2012
    Hi,
    I am looking to get the new max q version with GTX 1060 but it's so confusing to find. The model numbers don't make sense to me.
    Is there a max q version with GTX 1060? Ideally with 32gb memory and 4K display if possible, if not then 1080p is ok.
    Any ideas?
    Thanks in advance :)
  2. iRUSH
    iRUSH Gawd
    618
    Jun 4, 2013
    I would call XoticPC. Their customer service is great and they should be able to help you.
  3. KarsusTG
    KarsusTG 2[H]4U
    3,338
    Aug 27, 2010
    I don't believe there is a max-q 1060, they just released the 1070 max-q here recently.
    The primary difference is the max-q is designed to stop pushing at that peak performance per watt in the bell curve vs just the full performance of the card. That makes them a little slower, but much less power hungry. Because of the performance loss, if you were going to get a 1060 max-q, you might as well just get a 1050ti instead.
  4. lachdanan
    lachdanan Limp Gawd
    231
    Nov 3, 2012
  5. iRUSH
    iRUSH Gawd
    618
    Jun 4, 2013
    There is actually. I was surprised myself. The new Dell 7577 has a MaxQ 1060. Just in case you haven't seen this..http://www.dell.com/en-us/shop/cty/pdp/spd/inspiron-15-7577-laptop?~ck=mn
  6. KarsusTG
    KarsusTG 2[H]4U
    3,338
    Aug 27, 2010
  7. iRUSH
    iRUSH Gawd
    618
    Jun 4, 2013
  8. KarsusTG
    KarsusTG 2[H]4U
    3,338
    Aug 27, 2010
  9. iRUSH
    iRUSH Gawd
    618
    Jun 4, 2013
    No doubt! I've contacted them and their aware of this. Expect an update on their site soon.
