My main rig has two SSDs in RAID0 and 4 Hard Disks in a RAID10 all on the Intel Controller on the ASUS P8P67 Pro. The motherboard was replaced after the Intel SandyBridge chip-set issue.
One of the disks in the HD array started failing (SMART errors). I had an unused cold-back-up hard disk which I plugged in to replace the failing disk. The IRST rebuild the array.
After a few days, one of the disk in the array failed again. And guess what, it was the new disk I had put in the same SATA port is failing.
I have a suspicion that instead of the disk it is perhaps the port which was failing.
What would be the recommended way of debugging this problem?
