I downloaded a torrent file off of a website and it created the actual file that I used to download the file I wanted, but it also created this blank file on my desktop.
There is a file name "[TorrentReactor.to] - [prv net pl] STOYA Katsumi Katsuni Video Nasty 4.torrent " on my windows vista 64 business computer. When I try to delete it, I get a message that says:
"Could not find this item"
This is no longer located in *** Verify the item's location and try again.
The file is 0 bytes, and any attempt to move it from my desktop or to delete it brings up an error that says that the item could not be found. It says I need to verify the item's location and try again. I cannot rename the file or edit it in any way.
How do I get rid of this blank file?
I thought that the reason I couldn't delete the blank file was because I had already deleted the actual torrent file (the one used to start downloading the torrent in my torrent client).
Well, this wasn't the case, as I re downloaded the torrent file and attempted to delete the blank file. When I drag the blank file to the recycle bin, it doesn't go anywhere, but the actual torrent file (the one used to start the download) gets deleted instead (even though I did nothing to it!)
This is the third party program i had try
Chkdsk GUI - never solve
Unlocker - not support
Emco Move On Boot - can't deleted
UnlockIt - can't deleted
FreeFile - can't deleted
Also Command Prompt
cmd
In the command window:
del C:\Users\Eyecan~1\Desktop\[Torre~1
__________________
Result : Could not find this item
Pls Help me, Tq
Also Command Prompt
cmd
__________________
Pls Help me, Tq
