I have a ton of air in my tubing in my integrated pump/res/rad MCR220 Drive. This is what happens:
I run the pump water flow is fast. Res drains, water slows down. The res keeps draining and I am not seeing any leaks whatsoever except for a tiny one in my cpu block, not through the fittings, but through the block itself. Just ordered a replacement. The cpu block is absolutely not leaking enough water to be draining my res over and over again.
So it comes down to this:
How do I get the air out of my tubing? I do not have a seperate rad/res combo to do this easily. Do I run the setup with the res cap off or on? and how come my res is being drained repeatedly? I can post a video if that will help, but that will take some time.
Btw I have run the pump for less than 2 minutes total in short bursts. Good thing I spotted the cpu block leak.
