sirgallium
- May 30, 2006
So I delidded my chip. Now the motherboard clamp won't clamp enough into the pins without the extra thickness. So I just set it back on top for now with no glue and it works.
The heatsink can't really tighten down far enough to hold it down enough either and I'm not even sure if it's the best idea to put that much force through the die.
If I had spacers to go under the edges of the clamp then the heatsink wouldn't fit down low enough in the middle.
