How to convert GTX580 to single slot bracket?
undertheradar
^^^waterblock pr0n. As you can see, I have a couple Koolance single slot PCI slot adapters (performance-pcs.com doesn't carry the watercool brand ones, but watercool said the Koolance ones should work). Okay, so how does one go about attaching this adapter to the card? My two EVGA GTX580's will be here in a couple days, but I cant see how these can attach... has anyone here done this?
DarkStryke
You should just have to take off the DVI socket screws, and there should be another one near the top of the PCI-e bracket (near the bend) to the PCB.
