How to clone latest Win 10 Pro to another drive?
Discussion in 'Operating Systems' started by Bird222, Dec 13, 2019.
  1. Bird222
    Bird222 [H]ard|Gawd
    1,174
    Dec 1, 2000
    What's the least painful (and free) way to do this?
  2. Mazzspeed
    Mazzspeed 2[H]4U
    2,438
    Dec 27, 2017
  3. ir0nw0lf
    ir0nw0lf [H]ardness Supreme
    6,346
    Feb 7, 2003
    Macrium Reflect (Free) is another alternative.
    Legendary Gamer and RogueTrip like this.
  4. ManofGod
    ManofGod [H]ardForum Junkie
    11,409
    Oct 4, 2007
    It is not free, as far as making bootable media but, I would suggest Easeus ToDo Home edition. It is only $10 and worth every penny. It is also very easy to use.
  5. Bird222
    Bird222 [H]ard|Gawd
    1,174
    Dec 1, 2000
    Ok I used Clonezilla and it seemed pretty painless. However, Windows still reported my old drive size (new drive is bigger). I did the following:
    1. Booted into Gparted. It reported an error with the drive size and offered to fix it and I did.
    2. Resized the partition to use the rest of the unallocated space.
    3. Booted back into Windows. Still reported old size.
    4. Opened MiniTool partition I had installed. It reported the correct size of the partition. Didn't change anything just opened the app.
    5. Rebooted Windows. During boot it automatically did a drive scan/fix. After boot, it reported the correct size.
    In the future how can I get clonezilla to report the correct partition sizes afterwards?
  6. pendragon1
    pendragon1 [H]ardForum Junkie
    15,460
    Oct 7, 2000
    backerupper has worked perfect for me
    Puterguru likes this.
  7. pendragon1
    15,460
    Oct 7, 2000
    you can usually adjust it before the clone.
  8. Bird222
    Bird222 [H]ard|Gawd
    1,174
    Dec 1, 2000
    How is that done?
  9. pendragon1
    15,460
    Oct 7, 2000
  10. Shoganai
    Shoganai Limp Gawd
    504
    Dec 5, 2018
    As others have suggested ... AOMEI Backupper
    It’s all I use now. It’s never failed me.
  11. pendragon1
    15,460
    Oct 7, 2000
    lol ive been calling it backerupper for years oops.
    Shoganai likes this.
  12. Shoganai
    Shoganai Limp Gawd
    504
    Dec 5, 2018
    I think either way is fine. ;)
    pendragon1 likes this.
  13. ManofGod
    11,409
    Oct 4, 2007
    Does it let you create bootable media? I am not sure you can clone a live drive with it from within Windows.
  14. Bird222
    Bird222 [H]ard|Gawd
    1,174
    Dec 1, 2000
    I was specifically asking about Clonezilla.
  15. pendragon1
    15,460
    Oct 7, 2000
  16. Bird222
    Bird222 [H]ard|Gawd
    1,174
    Dec 1, 2000
  17. /dev/null
    /dev/null [H]ardForum Junkie
    14,358
    Mar 31, 2001
    Macrium Reflect free version.
  18. dvsman
    dvsman 2[H]4U
    3,043
    Dec 2, 2009
    I bought one copy of Macrium Reflect (during one of those holiday sales a few years back) and have been moving it from build to build. From the amount of time I saved, it was worth every penny.
